Here is my version of the AK record bin next to the media case I built a couple of weeks ago.
I built it so that I can remove the screws and knock it down for moving.
More pics, and a better description on my website.
One thing I want to mention here, so others can learn from my mistake. As you can see, I used the plan with the grain running vertical. But in my ‘version’, the grain on the back runs horizontally.
I started by having HD crosscut the sheet at the 39” mark so I could fit in my Grand Cherokee. And so I could maneuver the sheets alone on the table saw. I cut the sides out of the one piece with no problem. Then I went to cut the back and shelf pieces. Since the table saw can only rip to 24” or so, I set the fence to 48” minus the width of the back. So it kind of reverses my normal way of cutting.
In my mind, the good piece is the one between the blade and the fence, and the waste piece is to the left of the blade. But the way I had to rip this it was the opposite.
So I set the piece to the right off to the side, and grabbed the ‘waste’ piece to rip the shelves… Oops. I discovered it when I went to rip the fronts and dividers.
It worked out as I was able to turn the grain and by splining two pieces together, I could get a piece large enough for the back even though the .grain is horizontal. You really can’t see the back anyway and the seam is virtually invisible.
Thanks to sxty8goats for posting this, easy, fun project. And usefull too...
