Record Cleaning: Developing the Best Possible Methods
Status
Not open for further replies.
I'm using Hepastat 256 and was curious if other users are making a large volume mix 1/1000 and storing it to add at a later date?
Also the bottle had a 'handy mix' insert that I cannot get anything out of. I have to remove it entirely and then pour.
Not easy and you're dealing with small amounts.
Any one know how to use it?
Ollie, man are you right about that bottle and getting anything out of it. I'm on it though, have a call in to the lab that produces this stuff so they might enlighten me as to how to actually get it out of the freakin' bottle so we can use it! This is really outrageous, NO INSTRUCTIONS on the outside of the bottle to give even a clue as to how this "handy mix" thing is supposed to be so "handy." I will post back once the juice starts to flow......
The mix insert is removed and discarded. But folks.... be careful! Remember that Hepastat is a very concentrated cleaner. Treat it like bleach, which means wear eye and hand protection. If you read posts back a year or so, someone got some in their eye whilst removing the insert and ended up in the emergency room. Why they manufactured the bottle this way is a mystery, but work your way around it carefully please.
Yes it's some potent stuff.
I've been having great success with this solution.
And just adding a drop of Hepastat to my final rinse works wonders with static.
I'll be glad to see what you find out. As of now I'm just removing it and using a medicine dropper to remove the small quantity I need.
Well, I sort of expected this but here it is from the manufacturer:
"This product is for use with our handimix dilution control system only. Do you have the handimix dilution control system? The dilution system would have instructions on how to use the cleaners with it. If you have the dilution control system and still need instruction please advise. If you do not have the dillution control sytstem you would need to contact our advantage team to either set up return or to purchase this system."
So, on to removing the insert.....anyone done that and if so, how? I have a hunch this is going to call for some barbarian mangling.....or, maybe a drill through one of those two small holes in the insert? I hesitate to do that because I don't want to get any tiny shavings/drill residue in the mix that then may be transferred to the solution.
I can see how this may have become dangerous for the previous AKer who did not protect the eyes.
With regards to strength, most non-ionic detergents are much milder than ionic counterparts. Not even close to industrial strength. This is why they are often chosen for delicate biochemical extractions (like isolating a protein from cells without denaturing it) and are often included in products for consumption (Tween-20 in breath mint drops, for example).
Multiple rinses after the detergent step is typically recommended. These detergents wash away well with water, the only residual is a molecular layer, not something that necessarily affects playback in a dramatic way. That said, these molecules, in mass, will effect the properties of the record. If they are negatively charged (like SDS found in dish soaps and shampoos), they can contribute to the attraction of dust and particles (much of this world is negatively charged). If they are positively charged (like quats) they can neutralize static charge (PVC based plastics inherently acquire a negative charge). If they are neutral (like non-ionics) it is assumed they have no effect in this regard. The problem with Tween-20 and other detergents that biodegrade easily is that they are susceptible to mold growth. Dilute solutions of Tween must be used rapidly, not stored. Even the concentrate breaks down (turning yellowish) upon prolonged storage, releasing free fatty acids. For these reasons (and the fact that it isn't that easy for the average person to acquire) I have not recommended it.
So when choosing a detergent, there are a lot of factors to consider if you want to get really into it, like: How well does it solubilize the contaminants a record typically encounters? How much of the endogenous chemicals in the record does it extract? What is the minimum amount that can be used and still be effective? How does it effect surface charges? How well does it rinse off? Do the hydrophilic and hydrophobic moieties effect the record in other ways?, etc.
The real question though is how these surfactants effect playback and this it is mostly a matter of trial and error once a detergent (and useful concentration) is selected based on these questions. I don't think enough work has been done to determine the audible differences, if any, between one molecule or class of molecules and another. I have found that issues arise from low solubility detergents with super long hydrophobic chains as they can leave behind a waxy-like layer that accumulates on the stylus. But audible signature between Tergitols, Tritons, Tweens, and other nonionics?...simply not enough is known. I think this is mostly because we have focused on effectively removing the debris that actually causes noise in a way that best preserves the record.
Edit: I should add that environmental concerns are also a legitimate factor in choosing a detergent. In fact, Triton X-100 is set to be banned in the EU by 2021 as it is thought to negatively effect aquatic environments.
Thanks! Sorry for the delay in my response....a certain Schitt turntable arrived on my doorstep which left me distracted. :music:
That's great! Sold as a disinfectant/cleaner but also useful as an antistat/lubricant! ***
Some enterprising individual needs to rebottle that stuff into tiny bottles, call it 'Hepa-kleen' and sell it for 10x the price. ;)
Try again... HepaKleen is a registered trademark CLARK AIR CONDITIONING SYSTEMS, INC. :)
No wonder, Nice! Are you beta testing or is this an updated release?
________________________________________
ALL: Just a note that given that winter is coming (already snowing here in the Rocky Mountains), the heaters are running which means dry air and potential issues with static charge. I just put up an info post dealing with this subject in the Resource sticky. Would love to hear how folks are dealing with static in their systems.
Pray tell, "removing it" how?
I used a small knife and carefully worked around the edge lifting. Eventually I was able to use my finger tips and pry it out. Wasn't to difficult. When I put it back in I don't push it all the way in so it's easy to remove. I would suggest finding a small bottle to keep some in that's easy to use. I've started using contact lenses solution bottles.
Don't think I mentioned this but I bought a SqueakyClean and a small wet vac.
Using the excellent info on here I've been using distilled water from whole foods.
My process is -
Vacuum disk to remove any debris
Pour a small amount of cleaning fluid on disk and using Mofi pad distribute evenly making sure the disk is saturated. Give a gentle scrub.
I let it sit for a few minutes then scrub again.
Vacuum to remove
Add pure water and saturate the disk and give a gentle scrub with a second Mofi pad.
Vacuum to remove
Second rinse contains a drop of Hepastat. Using the small brush that came with the SqueakyClean work the fluid around and vacuum one rotation only.
Dry in rack.
This method had really worked well. Very little static issues so far but will see how that goes once the winter sets in.
Thank you, thank you, thank you!!! OK, so the problem starts with when you remove the foil seal, which leaves behind a small amount around the periphery. This will make it impossible for you to see the faint slit all the way around the opening that is the inserted "handy mix" apparatus! Remove the rest of the foil and it will expose what it is that you need to see. Once I did this, then I was able to see how OllieMeyer proceeded with the operation and used his recommendation of a small pen knife to insert in that slit, working my way around the top until it began to slightly lift out. Then it was easy, as he points out, to just lift it all the way out. What a nightmare! AGAIN, BE CAREFUL WHEN DOING THIS as the stuff is really concentrated and flat-out dangerous as phantomrebel mentioned earlier. Also recommend the suggestion by Olliemeyer to remove a smaller amount to another container for more frequent uses.
Do all of this at your own risk, and wearing eye and skin protection is a must.
Jesus...I never knew record cleaning was so complex. Never had to deal with it before. Just dusted records as they were mint. But I picked up some old ones that could use some cleaning.
I once saw a video of Robert Crumb washing his records with dish soap and water. Is that a simple method that works if you keep the center dry? Or do I need to buy some of the $$ cleaning kits on Amazon? I was worried about the 'proprietary' chemicals in the kits affecting the vinyl.
Thanks
Thanks
Read this developing thread. You might find a few answers there.
Record Cleaning: A Comprehensive Resource
Enjoy,
Rich P
Status
