Record Cleaning: Developing the Best Possible Methods
Status
Not open for further replies.
I was thinking of doing something and I'm going to ask for opinions (ducking and running) :)
I bought a Vinyl Style cleaner which uses brushes to clean the grooves, I've since picked up a Spin Clean and a Manual Nitty Gritty from Ebay...
Was considering doing wash bath on the Vinyl Style using the Spin Clean formula, then rinse in the Spin Clean, and vacuuming on the Nitty Gritty..
Then putting the disc into Mofi sleeves...
Any Thoughts?
Thanks Tim - envious! In a good way. Inspirational!
Hey John I lived in Lahr for 10 years when I was in the Armed Forces. I didn't even know they had a factory there until long after I moved back to Canada. Where do you live I have some X-100 I bought and brought back from AZ 2 years ago.
Hey Vince,
As some others out there have probably tried in the past, I have been using a mixture of 10 parts distilled water, 2 parts white vinegar, and 1 part IPA in a spray bottle that mists. I wipe with a soft terrycloth towel in circular and then straight around the grooves. Then I rinse with the distilled water, wiping and drying in the same fashion. The records come out looking and sounding great. What do you think of this concoction and should I be concerned about using white vinegar on vinyl? Thanks for all the great information also!
Hey Thunder - I just got my x100 and 99% IPA in yesterday; bought Sun Bum for the Quat and stretched my old math brain cells and made first the 10%/1% Triton/Quat stock. Then moved on to create a water bottle (20 oz) of ultimate wash and it works!! Still a little doubt about the math, despite triple-checking. What a trip it’s been first discovering Guest110/ Vince1 first posting a few weeks ago and twisting my mind around all formulas, 10% stocks, and finally executing it! Hope you’re having good luck with what you’re doing! Still waiting on the behentimonium chloride pellets for the Quat experiments! John
The rinse step can indeed benefit from a bit of quat (0.01% or less) to aid in static protection in future handling (sleeve removal, etc). This would be what I call "record conditioning". The choice of quat is important as the long chain, highly hydrophobic ones can be waxy and some quats are better antistats than others. For the average user, the quats found in products like Hepastat will work. Here is a subject that deserves a future resource post though, if nothing else so that commercial products can be improved.
Thanks from the audio community for this very interesting thread.
I don't fully understand this statement about the anti-static properties of the quat. How can it aid in future handling when (ideally) it is completely removed during the rinsing? Does it do something permanent to the vinyl?
Just for the record (no pun intended), I have never had a problem with static. I use anti-static sleeves on all my records and a carbon fiber brush before every play with my off hand touching ground. Been doing it this way for 20+ years, never an issue
I have just started US cleaning using X-100 + H2O + IPA. Based on what you have posted I will try removing the IPA from the bath. I am rinsing on a VPI RCM and it takes two or three cycles to get the surfactant off the record. If I don't do a thorough rinse, my stylus gets gunked up and the SQ suffers. So my learning so far is that rinsing is really important.
Read this on-going thread. I think things will become much more clear: https://audiokarma.org/forums/index.php?threads/record-cleaning-a-comprehensive-resource.884598/
Enjoy,
Rich P
Enjoy,
Rich P
Thanks,
I had already read the parts about static it says
"There are also home-made treatments. Antistatic sprays or sheets made for commercial “clean room” or household purposes contain quats, but they are not recommended for use on vinyl as they often contain additional chemicals (e.g. oils or solvent propellants) that can leave residues or potentially damage records. They are useful for treating carpets, furniture, and cables within the listening space however. Safe solutions of quats can be made (using pure cetrimonium chloride or cleaning mixes like Hepastat for example) and used alone, or as part of a cleaning solution, to provide antistatic protection. Keep in mind that while quats offer long term antistatic protection, they are not permanent and are subject to removal through wear or subsequent washing. Quat compounds are also effective antistats when incorporated into record sleeves or turntable mats."
I would interpret this to mean that after a good rinse, the quat is gone and you have no static protection. So what is the point in the first place? You see the issue, why recommend a quat when you wind up washing it all off.
Thanks,
I had already read the parts about static...
You really need to read the whole thread. You will find that you generally cannot successfully rinse off all of the detergents you use. There will always be a molecular layer left behind, and the type of detergent(s) in the molecular layer is important. This is particularly true regarding static effects.
The thread is not long, but very informative. You shall see.
Enjoy,
Rich P
hi friends,
couldn't go through the whole 101 pages, but grasped the sense...
I live in Europe, perhaps some of you do too,
I'd like to ask what are european equivalents for the mixture?
Hepastat 256
EDTA
Triton X-100
ISO ok, water ok;
and is the mixture thought for ultrasonic cleaners or i can use it in a knosti machine?
thanks !
Whew! Just did a search for "temperature" on this thread and looked at every instance the term appeared and did not find any suggestion about what temperature we should be setting our ultrasonic tanks at. AlexA6404 asked the specific question in post #1670 but I did not see an answer. So, forgive me if I missed it, (I also started a thread with this question but again, still unanswered) what is the recommended temperature? I saw comments about "heat is your friend" and such, but no definitive answer. I'm using a formula that is based on Rushton's, which was derived with the assistance of phantomrebel, but as phantomrebel suggested I am using less IPA (about half of the Rushton formula). One of the reasons I'm asking is that my newly acquired US tank seems to be malfunctioning a bit and the temperature gets to about 43C before I'm finished with cleaning my second stack of 3 records with my also newly acquired VinylStack system. I just don't want to damage any records and need to know, how hot is too hot?(title of the thread I started). Thanks in advance.
Thx, Thunderbox…..at what temperature will the vinyl be adversely affected? What is the most effective temperature to use with ultrasonic cleaning?
I use 40C but I preheat my water and have gone over that many times. I don't know what is the most effective temp is I just know you won't damage the records at 43C
Do you find that the temperature of the solution goes up after you have started your ultrasonic cleaner? That is what I am dealing with.....have others also found this to be the case? I see that you preheat your solution but I'm talking about after you start the US part. I don't even have to turn on the heater and it will go up. E.g., I started yesterday with the water at 22deg. C, nothing turned on, just the tank sitting at that temperature which in my home is "room temperature." (72 deg. F) After about 5 minutes of having the US on, still no heater, just the US on, the temperature was 26deg. C and then, after 15 minutes, it was up to 30deg. C.
I do not find the temp going up without the heater on.
See, that is what I thought and why I asked. My unit definitely has a gremlin goin' on and I'm in the process of trying to get it replaced. Brand new (1 month) and did not think it was supposed to do that. Thank you very much, Thunderbox.....very helpful indeed!
Could the US inducers themselves perhaps be heating the water? Any inducer will give off some heat when energized, but I don't know how much, and that's a lot of rise in a short time!
Status
