Record Cleaning: Developing the Best Possible Methods
Status
Not open for further replies.
If I am using the Triton and Hepastat mix diluted in my 2 gallon ultrasonic cleaner, can I get by with one rinse per side after I remove the records from the US cleaner?
I would think so, especially if you are keeping the surfactant concentrations low. The proof will be if your records are coming out without any films, spots, or anything accumulating on the stylus. How are they sounding?
I sometimes see film, but I think some of it was there before. My stylus still looks clean. I also sent you a PM to clarify some info. Thanks!
I just got an isonic 4875II with an MVR10. I highly recommend this unit and jerry at isonic gives great customer service.
My current process is
1. Ultrasonic clean
2. Rinse in Spin Clean
3. Dry with spin clean clothes
4. Vacuum on Okki Nokki.
3. is my issue, if I don’t do it, the underside of the record is still soaked when I put it on the vacuum. That strikes me as bad. But I am concerned that the cloths are not lint free. I have just bought new ones since the old ones definitely were leaving long on. The Kim tech paper wipes are just too small.
Anybody have a better system?
Had the same issue, cut a piece of heavy gauge vinyl, about 5 mils iirc, making a round piece about 1/4 inch larger than the platter and put it on the platter with the wet side of the record facing down upon it. Then after vacuuming the first side, removed the vinyl piece and put the dry side down on a dry platter because the vinyl piece had protected it from being soaked. You have to be careful not to get any moisture on the platter when removing the vinyl protector though, and that can become a bit of a pain although not unmanageable once you become familiar with the operation. On the other hand, there are other systems out there that attach the record just using the label area and that is what I have since constructed for my method after I tired of the process of removing/replacing the piece of vinyl....one such system is this:
https://audiokarma.org/forums/index...ho-have-one-or-used-one.865807/#post-13278757
My apparatus is DIY and I am unable to upload some images at the moment (something about "uploads are not available") to give you an idea.....but, it was not difficult! Check back later for pics.
Am I the only one who has found good results by using the ultrasonic for the rinse cycle with only distilled water?
I do the paint pad triton/hepastat wash/vac prior to loading the spindle into the tank.
Hi ETLS, that's a good question......as far as I'm aware, the advantage of the solution in the tank (triton/hepastat/IPA) is that it uses these agents to loosen anything that might be lodged in the grooves and does so better than if one were to use the paintpad method prior and then just distilled in the US cleaner. However, if whatever is working for you makes you happy, stick with it.
You might try it the other way though....I like just doing the distilled rinse(s) after the bath of agents within the US cleaner because it 1) takes less time, and 2) leaves the records in the cleaning solution far longer than the couple minutes they're on the record when using the paint pad method. Plus, the record is blasted (cavitation) with the solution containing the agents, not just distilled H2O.
I've done this as well with good results. There is the caveat, however, that highly pure, de-ionized water should not be used alone in an US tank due to issues achieving cavitation. For example, see https://techblog.ctgclean.com/2019/02/enhanced-cavitation/
One thing that makes the inclusion of a detergent useful is that, because the contaminants are surrounded by detergent or are emulsified, they are less likely to bind back to the record surface. This can be important when processing multiple records.
I like this idea. I think the heavy gauge vinyl could work well for me.
This one:
https://www.homedepot.com/p/Shur-Line-4-3-4-in-x-3-3-4-in-Paint-Edger-Pad-2006556/312065060
refills also available there. At least that's the one I use.
So just to add my $.02 to this Wagnerian-legnth thread...
I did a test batch of about 15 records in a USC with the Hep 256, Triton X-100, EDTA, IPA mixture.
First, if you are doing this method, I suggest using some kind of filtration system. I went cheap to start and took a pass on it. My cleaning solution is visibly filthy. Sure I started with some of the most problematic records I have, but this was after just 5 batches (I'm using a Vinyl Stack holding three records at a time). Second, Wow... I'm pretty impressed. Results aren't 'pristine' (and some of the remaining pops and cracks might be from my methods (how fast the VS was spinning, water temp, total spin time, sometimes I did a straight vacuum and others I did another DI water wash, etc.)) but this is way better than anything else I've tried. First batch had a record with mold that had resisted any other cleaning methods. Totally clean now and as close to new as a 35-year-old record could sound. So overall, it's been worth the time and expense.
Now, question... my Hep 256. has a secondary cap/seal under the childproof cap. It looks like it's for some proprietary delivery system. I cannot get it off or get around it or defeat it for the life of me. If I get the internal cap depressed I can get a drip out of the bottle. I did this, but it took half an hour to get a few mils out. And it was painful. Anyone else experience this? What obvious thing am I missing?
Start with post 1991 in this, thread, page 100.....you will see what is needed to be done. Read AT LEAST to post #2001 because that is where you learn how to remove the dispenser. Note the foil and that it needs to be completely removed which is where you start with the sharp small knife.....MAKE SURE you wear goggles and gloves.....this stuff will burn you bad.
Ha... literally four pages back. I feel really dumb. Thanks. And yes, I've been using gloves and eye protection.
Not to worry, and not as dumb as I when I first received shipment of the Hepastat and squeeze as I might, shake, rattle and roll.....nary a drop was given up by that dispenser!!! Carry on and welcome to the forum!
Santa brought me a US Tank and a vinyl stack.
I'll get some time to using it on Monday. My question is, how long does the vinyl need to be in the water for it be clean?
I figured 5 minutes would be plenty so a rotation of 10 minutes should be enough to clean an entire record.
Any thoughts on this?
I go for 15 minutes at the slowest rotation speed. Didn't actually time out how many revolutions that is. A couple of other things. Be careful with the Vinyl Stack. The circular metal plate you that the spindle attaches to, yeah, can't believe A) that thing has no rubber or plastic around it but B) it was totally my fault that I pulled the magnetic spindle off with enough force that a record got scratched BADLY after making contact. And it was one of my most valuable records (I'm super bummed and mostly because it's just a record that they're aren't a lot of good copied of and I ruined 2 songs on a VG+ copy... Still mad about this).
Also, you absolutely need to set up a filtration system. I did a small test run without one and was more than pleased. So bought all the pieces and was set to go but my pump was DOA out of the box. Since I had mixed up 6L of solution I decided to do a small run until the cleaning solution was too dirty to use. This is what 21 records looks like. And the pic doesn't even do it justice. I'd say only 6 of those records were visibly 'Oh god, that's filthy'. The rest looked okay to the naked eye. So, yeah. getting filtration working should be a priority
To those of us with the 1 gallon bottle of Hepastat, to retrieve the solution you push the strange looking cap inwards. This does not help in much as it makes a mess. oh well.
Yes, Brighton screwed up with their Hepastat packaging, trying to get clever. Good news is there are at least a dozen other manufactures making similar 256x quat cleaning products If you search around. Again, you can also obtain pure quat chemicals from various sources, which are preferred. Either way, I think it is worth the effort to experiment with them in your cleaning solutions as there are so many benefits.
Status
