Record Cleaning: Developing the Best Possible Methods
Status
Not open for further replies.
Interesting to learn that. I assume that Tergitol and Tergikleen have similiar NFPA safety ratings of 1 also?
The Tergitol SDS that I viewed actually has a heath hazard rating of 2. From what I am able to gather, Tergikleen is a mixture produced with Tergitol as one of the ingredients.
The hazards would come from getting the material in your eyes, or worse yet inhaling an atomized mist of the pure material into your lungs. The former would mostly cause irritation. The latter could severely affect pulmonary function.
By using common sense handling and hygiene methods, most of these surfactants should pose no problems when handled in the quantities used for record cleaning applications.
The active ingredients are organic ammonium salts, so yes, they can decompose over time. One year sounds a bit conservative though, and I would assume that there would be antimicrobial activity for at least a few years, for album cleaning purposes anyway. I suppose that the one year expiration timing would be prudent if you were using it to disinfect hospital rooms and such.
If there any way to test the effectiveness of Hepastat 256 that has been in use for a few years? You can't find this stuff anymore, so, it is good to know if I can use the roughly 3.5 liters that I still have, if it is still good. I can double or triple the ratio to improve the effectiveness, if it has weakened.
Personally speaking, I have albums that have been in my collection since the mid-70s, and for the life of me I can’t figure out why an anti-biological agent would ever be a necessary ingredient in a record cleaning solution. If I ever relocate to a hut in a rainforest, perhaps my opinion might change...
Well, part of the reason I am asking is to use Hepastat 256 to disinfect other objects against Corona virus, in addition to record cleaning. That is why I am interested in testing the solution that I have to see if it is still good and effective.
Triton X-100 has an NFPA safety rating of 1, out of a maximum of 4. It is potentially hazardous if it contacts the eyes or mucous membranes, much as any surfactant/soap would be. It is very safe as long as common sense precautions are taken.
If I order the $25 Triton X-100 from Amazon, what is the mixing process? Just add a few drops to distilled water? I recall reading that it requires some time consuming mixing process but it can be sped up with alcohol? Unclear on how much alcohol and how long though..
To make that 10% take 1 gal. water, remove 18oz. replace that 18% with Triton 100 x and you have your 10% solution
Moderation Note:
I moved the posts on using a plant-based surfactant to its own thread, as they were off-topic for this thread. This thread has a very specific, well-developed topic. Let's keep it that way, please.
Rich P
Hepastat 256 is hard to find these days. I came across this on Home Depot website:
https://www.homedepot.com/p/Simple-...ant-Cleaner-Case-of-2-2810000201032/313611288
https://images.homedepot-static.com/catalog/pdfImages/ee/eeb60f12-b70c-4633-b92f-e88db0f2ecf8.pdf
Water 7732-18-5 >95 * Tetrasodium EDTA 64-02-8 1 – 5 * Alcohols, C12-15, ethoxylated 68131-39-5 0.1 – 1 * Quaternary ammonium compounds, C12-14- alkyl[(ethylphenyl)methyl]dimethyl, chlorides 85409-23-0 0.15 Alkylbenzyldimethylammonium chloride 68391-01-5 0.15
It looks like this is some kind of quat based disinfectant. It is diluted, so can I use this in place of Hepastat? How much should I use for 6L ultrasonic tank?
Thanks!
Just confirming you only need to add a few drops to a gallon of distilled water? No heating, stirring etc?
I use some alcohol to mix it in first, and then add water to make a 10% solution. For final cleaning fluid, I drop a few ml of the 10% solution into water, and dilute it further to 0.1-0.5%.
No heating, some shaking and stirring, but not much required.
no matter what cleaning solution is used, everyone seems to have their own brew or mix. But the key to any of them is looking to see how effective they are. There are two groups of materials you are trying to remove from the vinyl grooves.
1. surface dust, lint, finger prints, hair etc. from the surface.
2. CaCO3, calcium carbonate.
most solutions are pretty good at removing item 1.
its really tough to remove item 2 from the grooves. If you use a microscope you will see the calcium sitting in the bottom of the grooves, hanging out on the lead in grooves and in the run out grooves leading into the dead wax..
that stuff is tough to remove. takes repeated applications of what ever solution you are using to break its bond to the groove wall.
But once you get it out, your vinyl will sound a ton better and be much quieter.
J'ai trouvé du Tergitol 15-S-7 500ml 82 €, Il faut trouver une entreprise car les laboratoires ne vendent qu'aux professionnels.
Il me reste à espérer que cette achat :
Hexadécyltriméthylammonium chlorure
fera l'affaire pour remplacer HEPASTAT 256 (https://www.ebay.fr/itm/Coastwide-Professional-Hepastat-256-32-Oz-CW4250SB-A/202858749005?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649), impossible à acheter vers la France. Je serai livré en Octobre. je vous tiens au courant.
I couldn't have said it better myself. :thumbsup:
Status
