Welcome to AK!
I just ordered some Equifect 256 to go with my current supply of Triton X-100 to try out with my next cleaning "session".
Will you be using IPA as well? I assume you will be mixing the Triton and Equifect 256(which I assume is the same or similar to Hepastat 256?) in a distilled water solution? What will be your percentages? Here's what I have been using based on the much-appreciated work done by Phantomrebel with very slight modification:
Get an empty container that you can seal after use. I use an empty IPA bottle which works quite well.
Side-note - I keep the Triton in the fridge so it will not degrade. Careful if you have others in the household, put it in a ziplock bag and write POISON on it; could use some skull and crossbones drawings as well to drive the point home. Then, tell everyone what it is and that it will eat you from the inside out if you ingest it. That should keep things under control.
In the empty container, pour 50ml of the Triton, 38ml of the Hepastat (or in your case, Equifect), and 72ml of IPA to make a total of 160ml. Swish it around for a while until you see that it has blended well. The IPA will help with dissolving the Triton, which otherwise is difficult to mix.
You now have enough solution to do 8 tanks if you have a 6 liter tank at 20ml of the solution per tank.
When I first received my 6L tank, I was surprised to find that the "full" line was just a small amount over 5 quarts, so that is what I use for the distilled portion......5 quarts. Pour 5 quarts of distilled water into your 6 liter tank and then 20ml of the solution you just made up. Then, add 150ml of IPA to the tank and turn the thing on. Let it run about 5 minutes and then turn it back off. This is to de-gass the solution. You are now ready to start with cleaning records. Enjoy!
Another warning: IF the Equifect is similar to the Hepastat, use extreme care not to get any of that on your (or anyone's) skin. In concentrated form, this will also do bad, very bad things to your skin. I inadvertently got a tiny drop on my hand the first time I did this and didn't notice until I felt a strong burning sensation. Lots and lots of water and a few hours later, it stopped burning.....and I'm talking about a very, very tiny droplet that splashed up on me as I was removing the dispenser from the top of the bottle.....there's some information in this thread about that and how to do the job but it ain't easy, so pity should your Equifect have a similar dispenser. The problem is, you can't get any of the stuff out of the container without first removing it. It is intended to mate with another device that attaches to a cleaning machine so the proper mixture will result for hospital (institutional) cleaning.
I've since gone to rubber gloves to do my mixing and should I have to deal with another proprietary device such as was in the neck of the Hepastat bottle, I will be wearing eye protection as well so just a word of caution about these concentrated, powerful cleaners.
Have fun and be cautious.....
Thanks for the info, you may have saved me a lot of homework. I will simply use your "formulation" this go-around. Hearty thanks for the warning on spilling to stuff on me; definitely will need to use gloves. Now I have to go find a suitable container and methodology for accessing the liquid (guess too much to expect a screw-off top cap...).
You are welcome, and yes, you can now get to it instead of having to do all the homework! That said, I owe much to Phantomrebel and another cat by the name of Rush Paul who wrote extensively on the subject and contributed mightily to my knowledge and understanding. I was overwhelmed for quite a while, thinking I wanted an ultrasonic cleaning arrangement for well over a year but intimidated by the unknowns. They pointed me in the right direction and I'm merely "paying it forward" amigo. I don't think you will be disappointed in this formula but do share what you find in terms of how it works for you.
So, did you find that your Equifect also has such a device in the top of the bottle?
Slightly View attachment 2007280 off topic question. I just got a zero dust stylus cleaner. I actually have my disc washer system from 1980, but there are those that say the zero dust is the better way. Any opinions. As an optician, i use non alchohol bases anti reflective lens cleaner with my discwasher pad to clean record before i play them and it works great as it is anti dust and anti static. But any opinions on the zero dust for the stylus diamonds.
