Record Cleaning: Developing the Best Possible Methods
Status
Not open for further replies.
I bet you are well below the limits, but it would be useful to know at what pressure and distance water begins to etch vinyl. Just to know.
LOL yea, I only give it about 10 -20 pumps. Nowhere near 45 PSI. But the thick plastic housing and jug withstand pressure better than those cheapie, plus has a pretty solid nozzle. Was bought at a farm supply in Oxnard CA. $25? Maybe a bit more. Holds 1 gallon.
My 1 post and allready a question, I am waiting for my triton x 100 to arrive and i want to know how to shelf the triton bottle in a dark place ? or in the Fridge ? Thanx for the answer i will give my impressions next week when i have done some cleaning.. I will do as folow :
4 cups of pure distilled water
1 cup 99% isopropyl alcohol
Few drops triton x 100
Any better suggestions maybe ? Sorry for my English.
That would give you 20% alcohol. 5% is what is being recommended here. Read the beginning of this thread for how much and how to add the Triton.
My question to Vince and others is, how does one know when the mixture is at the end of it's shelf life? Apologies if I missed it in this long thread.
So it's better
950 Mililiters of distilled water
50 Mililiters of Isopropyl alcohol
Few drops triton x100 Mix solution
When stuff starts to grow in it or precipitates form. In a sterile environment the detergent will last seemingly forever (though UV can break it down slowly), but it's microbial growth that can degrade it. So you keep it in the fridge or add a preservative (e.g alcohol, thimersol, azide, or a quat). I like adding quats because they also are anti-stats. The 5% IPA is also good. It's easy for me to use autoclaved glassware and solutions so I forget sometimes that microbial contamination can be a problem in some environments. Nothing seems to grow in the 100% Triton stock, but you can keep that in the fridge as well if you want.
Yes, I try to keep alcohol below 15%, with 5% being most common.
Oke thanx i will do some tests in the weekend and will report my results.....
I have one question when you mix the triton solution and you let it perform overnight must i let the bowl in the fridge to do his work or can i just left the bowl overnight in my room until the morning.
Vince, I plan on using Triton and since I may go a months between cleaning sessions, I'll make a small batch of cleaner each time. My question for you is how long will the Triton X-100 last at 100% concentration in the bottle that I will purchase? Will it still be good for several years to use to clean records?
Yes, room temperature overnight, no worries. If there is a concern, dissolve it in an ounce or so of 50% isopropanol then with water and you can use immediately (no need for overnight solubilization).
I've had a bottle of 100% in the fridge for 8 years that works fine. I make fresh working solutions too.
I hope this is the right place to post this question. I occasionally find records that I want in GW. I have been looking for a copy of the Saint Saens Symphony No. 3 conducted by Charles Munch for a while. I have found one or two badly scratched copies before. Today I found a copy in a badly water damaged jacket and water damaged sleeve. However, the LP looked clean and shiny. Nevertheless, I hand cleaned it with home brew. I have a Record Doctor, but will not have access to it until the weekend. Even though it appears clean and shiny, the LP is very crackly. Could the cause be mold? If so, what can I do about it?
So how does this sound for a process?
  • Clean with Triton/Alcohol/Distilled Water Mix in Spin Clean #1
  • Vacuum with Record Doctor #1
  • Rinse in Distilled Water in Spin Clean #2
  • Vacuum with Record Doctor #2
Just got done with a batch. Lengthy process but worth it. Hit each record with the antistat gun afterwards. Significant improvement. This is the way to go for DIY formula!
Hi Iramegdal. I find this can happen with some used records when the previous owner(s) abuse them. Sometimes it was played with a poorly adjusted cartridge, bad needle, or they never cleaned them and dirt wore into the grooves. This type of damage is irreversible, as is mold that has eaten away the record surface (they secrete acids and other chemicals that over time degrade the PVC). Rarely it can be heat damage or a bad pressing. Some stylus geometries are more sensitive to condition than others. On the other hand, it could be deposits of contamination that is treatable with enzymes, or even PVA glue (as a last resort). You can determine the state of the grooves and what you are dealing with more easily if you have a microscope. There are some under $100 USB ones on Amazon (e.g the Vividia 2.0MP) that are quite good and can also be used to examine your stylus periodically for condition.
My recommendation would be to first try an enzyme treatment followed by detergent wash and distilled water rinses using your record doctor. If the problem persists, and you are ready to toss the LP in the trash, try a PVA glue treatment, but wash afterwards again with your record doctor. If that doesnt work, into the trash bin it should go. If it works, you need to treat that cover to kill the mold since it was previously wet. I would wipe it down inside and out with Sporicidin and maybe even give it an ozone treatment before putting a restored clean record (in a new sleeve) anywhere near it.
Made a batch tonight and cleaned and vacuumed some records. They look great, and sound so quiet and clear. Thanks vince1, and hi*ball!!!
Way to go guys! So glad to hear your results. Be sure to post tips for others switching to this type of cleaning. If static remains an issue, you can try adding a quat to the mix.
Well I tried the Triton mix in my "Spin Clean" machine last night and the result was a HUGE improvement. Well worth the effort and Thanks Vince! Going forward, do I do this cleaning process every time I play the record? It is the double rinse in DI that makes this a long process and uses up the whole kitchen.
Before I was enlightened, I just used the "Spin Clean" with the cleaning solution they provide, and wiped the LP dry with the cloths they provide and put the vinyl directly on the turn table.
Great to hear Gary! You can condense the space needed for cleaning and drying if you use rubber coated dish drying racks.
No, you likely only need to deep clean once, if handled and stored correctly. From here forward, only light touch up is needed. I recommend a very dilute wash solution or just dH2O for this.
Vince,
Thanks for the interesting thread, unfortunately I didn't find it before purchasing Tergi-kleen. I haven't used it yet but wanted your feedback on the product.The msds sheet says it's Tergitol 15-S-3 and -9 and I believe they recommend 10-20 drops per gallon of distilled water. Should I use this as I would a straight Tergitol to make your cleaning mix?
In addition, what are your thoughts on steaming cleaning before the enzymatic cleaning for dirty vinyl ?
Status
