For some ultrasonic formulas I've seen, it's more a matter of having something to reduce surface tension, than to use a detergent. And I've seen one where a small amount of IPA is used to break down greasy fingerprints.
Interesting how this all works!
This is why detergents are referred to as surfactants. This is how they work, significantly lowering surface tension of aqueous solutions. And they work best at solubilizing oily contaminants when they form aggregates like micelles. There is a lot of cool chemistry involved, including how they produce bubbles leading to foaming (as well as a lot of equations to try to explain the physics of how they work). IPA's main action on the oily prints is as a solvent, but the detergent is what sequesters the oils and keeps them from adhering back to the vinyl surface (they are happier to be in the detergent micelle). The micelles are polar on the outside so are easily washed away (with incorporated oils) in the water. Sometimes the oil contamination is severe, they can be combined with proteins or sugars, are tightly bound, and they need to be broken down in order to get them completely solubilized. This is why you can sometimes still see fingerprints after washing records. Dirty fingerprints really present a problem as they attract further contamination (both things that stick to the oils and things that feed on the organic contaminants). The older they are, the worse they get. Enzymatic treatment breaks these down to smaller components that can be more easily solubilized by the detergent or solvent. Much can be avoided simply by washing hands before handling records and sleeves but people are generally lazy in this regard, so we need to have tools to deal with it.
