Record Cleaning: Developing the Best Possible Methods
Status
Not open for further replies.
Still find the final solution beading up.
This is what I did. Made an initial solution of 10% Triton; 3ml Triton mixed with 3ml Isopropyl, followed by 24ml distilled water. The Triton looks dissolved and looks like a cloudy solution. Then used 1% of this and adding 99% water for the final solution. As it was still beading I finally went up to 5% / 95% solution.
I took two pictures one when applied the solution and another a few seconds later showing the beading effect.View attachment 738956 View attachment 738957
Funny, my Triton solution is perfectly clear. I use just the Triton in water mixture. No IPA. Not a bit of beading either. It just spreads out as nice as you could want.
I don't do the 10% Triton mix in advance as Triton does not lend itself well with mixing with polar water molecules.. I use 3 ml of pure clear Triton into the 85 ml of 99% non-polar IPA (65 ml would be adequate) and mix that up. You need a large amount of IPA to fully dilute the large chain Triton otherwise it won't properly disperse in the main volume of water - not a one to one ratio as you seem to have done. 3 ml of IPA using your technique is insignificnt IMHO. The brushes I use are definately a big aid in spreading the solution out thinly on the LP surface. Also my Triton is completely clear....
With that mix going into 1 Litre of dH2O you have enough to last a long long time (at my useage rate anyway as this is my cleaning technique}:
Here is the TNT Audio link How-to: record cleaning devices and fluids
^^^^^ click on link above ^^^^
Talks about using 1 drop of Triton per 4 liters (1 US Gallon)
. Then used 1% of this and adding 99% water for the final solution. As it was still beading I finally went up to 5% / 95% solution.g
When you added 1% of a 10% diluted solution, you made the percent 1/10 of 1%. If you would have added 1% of straight IPA to your 99% water you would have a solution of 1%. The reason it's beading up is you have too much water. I follow Vince's formula of 0.5% Triton and 5% IPA and it spreads evenly on the lp.
As for the mixing of the Triton, I add the 0.5% Triton to the 5% IPA, let it sit for a day, no mixing, and it's ready to add to the water. I make 16oz of solution at a time.
Thanks for the help everyone, I think I know where I'm going wrong. I got confused with the 2 stage of mixing the ingredients. To summarise, the percentage measure used for the formula are :-
tcss - 0.5% Triton mixed with 5% IPA, then add 94.5% distilled water.
Timothy - 0.3% Triton mixed with 8.5% IPA, then add 91.2% distilled water.
tcss - by not mixing the 0.5% triton to 5% IPA, I wonder if this method have any benefits?
What I thought was a simple job is turning into a frustrat task. I'm still experiencing beading using Timothy's formula. I going to try tcss's next but not expecting miracles.
You know what you may consider? Maybe there's something on the record you're trying to clean that's causing the excessive beading.
Since you're going to be cleaning it with the triton solution anyway, why not first give it a quick bath with just a plain dawn solution. Then follow up with the 'real' triton clean. It might just be some type of film on the record you're trying that doesn't let the triton bite through.
Just a thought, YMMV and all.
Try this way simple mix. Take I liter of Aguafina and squirting 5 MLS of the Triton directly in it. Let it sit overnight, shake well and try that. This is what I do and I've never had the problem you are having on the hundreds of records I've used this on new and used.
Latest experiment (feel not a chemist already), to make a 100ml cleaning solution I added 0.3ml Triton to 8.5ml IPA and mixed until no bubbles left (triton was instantly dissolved). Next I added 10ml of water and noticed bubbles (some quite large) started to appear, mixing it made the bubbles smaller. Added another 10ml of water and mixed again, still have small bubbles. I then tried this solution on the record and it seem to not bead as much, only on the 1" run out groove where vinyl is smooth. Next I continued to adding more water until I reached a total of 90ml.
In summary, the solution consisted of 0.3ml Triton + 8.5ml IPA + 90ml Water. At this final solution the beading returned.
For info, the IPA is 99% Isopropyl.
When I shake the bottle, the solution clouds up as in the photo. Not sure if this is normal.
Another question, has anyone made 500ml or less and found no problem? I'm reluctant to make large quantity as I don't have alot of distilled water and IPA and wish to minimise waste. Already dumped 1.5L.
I have tried L'art Du Son cleaner and that does not bead, as I thought too that the record might be at fault.
EDIT: Corrections in Red (I wrote the org at work while packing up to leave).
For a 50 ml batch of solution:
(1 teaspoon = 4.929 ml> say 5 ml for those using droppers)
5 ml (1 teaspoon) of Triton X-100
45 ml (9 teaspoons) of Distilled Water
Mix solution and let sit approx 10 hrs (overnight) or add 99% IPA to speed dilution
From Vince "You want a final concentration of detergent around 0.1 to 0.2%"
50 ml = 1.69 oz
1 gal = 128 oz
1.69 oz solution / 128 (oz/gal) water = 0.013 =1.3%
therefore
1.69 oz of solution to 1 gal water = 1.3%;
1.69 oz of solution to 10 gal water = 0.13%;
Use 5 ml solution per gallon of water [for .13% concentration (light rinsing & ultrasonics), use 50 ml solution per gallon of water for rough cleaning]
So for my 10 L Ultrasonic Cleaner that uses 2 gals of Distilled Water, I would need 10 ml of solution.
For the Spin Clean tank that uses 24 ozs (.1875 gals) of Distilled Water, I would need 2 ml of solution.
Vince, I will give this a try. I experimented with Dawn but usually use Ilfotol. It took about 45 ml + to start foaming with the Ilfotol.
Thanks
I hope I don't get my face ripped off or anything, but I just would like to get some clarity for myself. I'm getting dizzy reading all these threads and posts on LP cleaning solutions. I have a spin clean. I like it for what it does. I am just about out of the cleaning solution that came with it. I have acquired a bottle of Triton X-100. My intention is to use a 10% stock solution of Triton X-100 and distilled water. I have measured the volume of distilled water the Spin clean tank will hold. It will hold about 700ml. How much of the 10% stock solution should I add to the 700ml of distilled water in the Spin Clean tank? Would 7ml be a correct amount to add?
Donal64, If you added 7ml of just Triton (100% solution ) you would have a 1% Triton mix in the 700ml of water. Adding a 10% Triton 90% water stock solution to the 700ml, you will have 1/10 of 1%.
I don't think it will be easy for the Triton to dissolve in just water. What percent are you aiming for?
My solution is perfectly clear. It suds up for a few seconds when shaken but there is no cloudiness. Something is "clearly" wrong. Good thing we chased Vince away. :rockon:
I know that Triton will dissolve in IPA instanteously, what happens when you start to add water to this. Does it produce bubble like objects like mine does.
I do wonder if my Triton has gone off although it has a expiry date of 2021.
I have not mixed Triton with just water, but have read here that it may not dissolve. I put Triton into the IPA and after 12 hours I can see some Triton swirling when I swirl the bottle. I do not shake the bottle. After 24 hours the Triton is dissolved and crystal clear. What is left in my 16oz ( 500ml approx) bottle that I made 5-6 weeks ago is still clear and I shook the bottle just to be sure.
I keep the bottle of Triton in the refrigerator so hopefully it will last for many years.
It dissolves just fine. I just put my 5mls of Triton in the liter of room temperature and within a few hours, the gel is completely gone. I swirl it a bit to speed it up but other times, I just leave it overnight. Made liters of the formula as described without any problem.
From reading the various posts, it's my understanding that a solution of Triton X-100 1 part with distilled water 9 parts, which would give a solution of 10% Triton X-100, is what is desired as stock solution. How much of this "stock solution" should I add to the 700ml distilled water in the Spin Clean tank to be effective? I also read that the Triton X-100 was difficult to dilute, but I mixed some earlier and set it aside and it seems to have mixed just fine. I need to dilute it one more time to get to 10% Triton X-100.
Status
