To recap. I recently became interested in vinyl again, and acquired a decent turntable and a Spin Clean. I am satisfied with the job the Spin Clean does. The small bottle of solution that came with the Spin Clean is nearly empty, and seeing the cost of the large bottle of replacement Spin Clean solution, thought I'd come out ahead by making my own solution. Was hoping to make a solution similar to the Spin Clean solution. Made myself dizzy reading oodles of posts/threads. Acquired a bottle of Triton X-100 and got to work. I determined the Spin Clean tank holds about 700ml distilled water. I determined the three capsful of solution poured over the brushes in the tank equals about 11ml of solution. I had diluted my Triton X-100 to a 10% solution with distilled water. That's one part Triton to nine parts distilled water. I poured 11ml of this 10% solution over the brushes in the tank. When I cleaned my first record, the water definitely did not bead. It was a solid sheet on the record and it did something that the Spin Clean solution had never done. When rotating the album, some of the solution ran down, over the label, getting it wet. Another thing I noticed was a little bit of sudsing bubbles, not a whole lot. I think my solution was a bit too potent. When I emptied the tank and rinsed it, there was a lot of suds.I diluted the 10% down to a 5% solution. I now have a gallon of this stuff. I will use this on my next cleaning session and see how it goes. I may have to dilute it further. I will never run out of this stuff! I cleaned the LPs in the Spin Clean, several rotations clockwise then several rotations counter clockwise. Then I would remove and spray liberally with distilled water and dry with non-abrasive microfiber towels, then would put on my drying rack to finish dry. I've listened to three albums, using headphones. I do notice a bit of static. The first album, I played about three times on one side. and with each playing the static decreased, it wasn't real bad to start with. And these albums are used, with unknown histories. Overall, I'm satisfied with the solution. Might maybe wouldn't mind trying a flocculant agent, if anybody has any clues about what or how much to use.
