I guess people may not want to go through 470 some odd posts so it might make sense to summarize:
We’ve been using non-ionic detergents (Triton or Tergitol) to clean our records as recommended by preservationists. They are superior to common detergents (e.g. dishsoap or shampoo) as they do not introduce a negative charge which can promote static and solutions of them are neutral in pH. Like most detergents, they have long hydrophobic tails that help solubilize things like fats and polar head groups that make them soluble in aqueous solutions where they form micelles. We use them at a final concentration of 0.1 to 0.5% for initial cleaning of a dirty record. We also (optionally) add a bit of isopropanol solvent to aid in fluid dispersion and releasing contaminants. We are keeping the final concentration of alcohol to 15% or below to reduce the risk of extracting useful plasticizers incorporated in the vinyl. Some of us are also adding a cationic detergent to our mixes. These are quaternary ammonium surfactants (often called “quats” for short) that are antistats and have antimicrobial properties. They are typically found in hair conditioners and antistatic products (like fabric softeners or Statiguard). An example is Behentrimonium Chloride, and we have been including them at 0.05% or lower. A few adventurous audiophiles here are also experimenting with adding EDTA, a chelating agent, that binds and solubilizes iron, magnesium, and calcium deposits (major minerals found in water). Finally, in cases of very grimy records, we have discussed a method of enzymatic treatment prior to detergent cleaning that helps solubilize fats, sugars, and protein, the main organic contaminants found on surfaces.
So in a nutshell, that is what folks here are playing with and the results have been great. We have gone away from treating our vinyl with harsh household cleaners or introducing chemicals that aren’t compatible with a delicate surface intended for sound reproduction. One theory behind the use of the specific detergents is that they also leave behind a molecular layer that helps keep the surface conditioned in a way that reduces friction and does not introduce negative charge.
Much of the discussion has been on the best way to prepare and store these ingredients. For example, the Triton needs time to dissolve so we make a 10% stock solution and keep it in the fridge, or we dissolve a small amount of Triton first in some isopropanol, dilute it up with water, and use it up in a batch wash. Other parts of the discussion have been on methodology, most advocating the use of ultrasonic or vacuum-based cleaning machines. I recommend reading the entire thread if you don't already have a cleaning protocol. Also, stay tuned as many are just starting to tweak their formulations so we should have some great further discussions coming up!
