Zerostats are pretty much ineffective if used on a record that is in place on a platter. This is because the ion stream sucks straight to any grounded metal, like the center spindle.
As an engineer, I can confidently state that there is little to no possibility of damage to electronics, unless the emission point is very close to a conductive equipment part that leads directly to sensitive electronics, such as metal control buttons or switches, or cartridge connections. "Very close" means closer than the 3/8" internal connections, where internal arcing will tend to take place (the snapping sound you hear if squeezing too fast). The internal arcing limits the voltage generated. If you purposely zap a button or connection, that is a different story.
Proof that the Zerostat works as desired, is seen in the statically charged LP clinging hard to a bit of debris, releasing that debris upon tipping and light blowing, after a shot or two from the Zerostat.
Remember, the Zerostat is essentially ineffective with the LP on the platter. The proper method is to hold the LP in one hand and squirt it with the Zerostat, one or twice, generally, before and after the brushing step. It doesn't hurt to squirt it once before inserting into its sleeve. In your hand, there is no possibility of damaging ANY sensitive electronics, PERIOD.
Enjoy,
Rich P
