I've noticed that atmospheric pressure has an impact on cleaning my records. On days with high pressure, the clezning process seems more in depth, if you know what I mean, and clicks/ rumble is reduced. On low pressure days, the records are still cleaned, if course, but, given low pressure usually means higher humidity, so they don't seem to dry as quickly. This seems to lead to a slower sound and higher inherent rumble.
I'm guessing that the slower drying times is allowing dust to settle into the groove, thus creating the higher rumble. That also adds weight to the record, meaning (I use belt drive exclusively) the records are heavier, put more strain on the motor which then turns them more slowly.
The only other explanation would be that higher humidity is contaminating the de-ionised water, but this seems far fetched. Anyway, I only clean my records on sunny days now, and only in the cold room I had installed as trmperature also has an impact.
