Record Cleaning: Developing the Best Possible Methods
Status
Not open for further replies.
No problem here using the Triton that Hi-Ball sent without IPA. My final solution container is a old Mo-Fi larger bottle a Qt IIRC, which I fill about 3/4 full with distilled water. I put in about 10 drops of the 10% that I received and add a couple of drops at a time until the final product will "Wet" the record. Very happy with the product. Used in conjunction with a VPI 16.5
Thanks to Hi-Ball for the product.
How are you folks, that are using Tergitol or Triton with a vacuum RCM, performing the rinse step? We have been told that a rinse step is needed, unlike the MoFi Super Record Wash.
Enjoy,
Rich P
I'm using Tergitol NP6 ... two drops per 8oz ... 10% ISO (99% pure) ... 90% Aquafina .... I'm not using a rinse step ... that's one of the reasons I use as few ingredients as possible ... 90% water.
I rinse twice using a cotton makeup cleansing square. I cut them in half. I use the one for the final rinse on the first rinse in subsequent cleanings. Totally prevents cross contamination.
I spray distilled water on the record and use a separate brush from the cleaning solution and spread. If it beads up vacuum and your done. If it doesn't bead much a second application of water until it beads on the record then vac and play. What I found for used records is to give them a pre-wash and rinse in the sink as has been suggested and it has made the final cleaning on the Vac set up much more effective.
:beerchug:
This post covers the last few members comments.
The only reason to make a 10% Triton ( 90% water ) stock solution is to have a quick mix of dissolved Triton ready to use to keep cleaning records when you run out of formula. I just mix a fresh formula using 100% Triton and have to wait till the next day to use it.
For the people who use the 10% Triton (90% water) stock solution, remember you need to add 10 times as much of that solution as do we who use straight ( 100% ) Triton. I use 1/2 teaspoon straight Triton to 16 oz ( 1 pint or 1/2 quart ) water to get 0.5% formula. I would guess that 1/2 teaspoon is about 5-10 drops. If you are using the 10% (90% water ) stock solution you would need 50-100 drops.
As for rinsing, remember none of this record cleaning/rinsing is needed. This is all about what you want to do. I use two Mofi brushes, one for cleaning and one for rinsing with just distilled water on my vacuum RCM.
Spin Clean, if you want 0.5% Triton with the 700 ml of water, you need 3.5 ml of 100% Triton. If you use the 10% ( 90% water ) stock solution you need 10X 3.5 ml
It seems to me that using only the Triton solution in the Spin Clean may not be the best practice. The SC solution binds to the crud particles and drops them to the bottom of the tank. Without it, after your first record, you're just running the rest through progressively dirtier solution and brushes, which happens even with the SC solution, so I imagine it would be even worse without it. It may be worth it to see if you can use the SC solution along with the Triton, followed by a good rinse. I may be off base there, but it's something to consider at least.
I just clean with the Triton solution and then follow with a distilled water rinse using a different brush.
I think I read that there is some concern that the cleaning solution forms bubbles when shaken. Let us not loose track of the fact you are essentially making a soapy solution (albeit non-ionic in nature) but it will of course produce suds when shaken. Really an over-glorified dish soap. From what I recall from Vince's input, it is the IPA that does the better job of breaking the surface tension (hence eliminating the beading) than Triton (which also does this a bit but perhaps not as well as per http://dowac.custhelp.com/app/answers/detail/a_id/1666/~/triton-x-100-surfactant-surface-tension). IPA is also a very effective solvent when the universal solvent (aka water) is ineffective. Each portion of the cocktail serves various functions on the whole
See:
http://study.com/academy/lesson/what-is-isopropyl-alcohol-uses-structure-formula.html
Also, there is a need to be careful when using the percent moniker without quantifying it as %volume or % mass as they are completely different beasts that will produce different ratios of mixture (akin to what I call the old beer wars) - many scientists use %mass as their fall-back I would think....
5% by volume of alcohol in beer is a different amount of alcohol from 5% by weight (as it was incorrectly labeled for many years by some companies - should really be by mass as weight is very often confused with mass). Read this to better understand the concept:
http://www.dummies.com/how-to/content/understanding-the-alcohol-content-of-beer.html
Timothy - Interesting links you provided, and my attention was drawn when you mentioned beer :)
I think I remembered reading that Vince recommended using 5% - 15% of IPA. For argument sake, lets say 10%, so for 1L of solution we will add 10ml of IPA if I'm not mistaken.
What I have found, is by adding IPA it makes the solution cloudy, with just Triton and water it is crystal clear. Has anyone seen that?
Again my point exactly - what he didn't mention was whether the percentage he was quoting was by volume (which you are clearly assuming) but as he is more closely aligned on the science side of the house I have assumed (as have others) that he may have meant %mass in which case your numbers are slightly out. Again, this ain't rocket science but....
Suggest reading posts #701, #708, #709, #713, #714 and #715 of this thread (Page 36) to get a better feel where I am coming from...
Just tried my latest formula after waiting 24hrs for the Triton to fully dissolve. I sad to say it is still beading.:mad::(
I've tried deionised and distilled water and different bottles of IPA and still not made any difference so I guess it might be the Triton is the culprit. I'm now looking for another source apart from Ebay as the others sellers there seem to be backstreet type or based abroad. Can anyone recommend a UK supplier (before anyone mention, I've googled it and only found supplier for businesses).
Have you tried using your cleaning brush to knock down the surface tension? The IPA (I use 99%) should do a good job of that alone if you use it in high enough concentrations. Even then the surface tension doesn't entirely go away - some beading will still occur me thinks (at least it does with my soup). A few swipes of the brush spreads it out thinly enough I would say....
See my video posted previously (Post # 869) to show what type of brushes I use which work very very well....
Yes, I'm using the MOFI cleaning brush http://www.mofi.com/product_p/mfslbrush.htm. All it does is push the liquid around the record leaving circular lines of beading around the record.
I've also applied L'art Du Son cleaner and this spread like a sheet of water across the entire surface of the record, link to the product https://www.amazon.co.uk/Vinyl-Reco...8&qid=1464734344&sr=8-1&keywords=l'art+du+son
Nice video except for your taste of colour, a pink :eek: record. Couldn't really see the spread of solution applied for any conclusive comparison. Anyway I ordered an overpriced small bottle of Triton X-100 of eBay and hopefully will provide me an answer to my problem. Should arrive by the end of the week.
I like the squeaky RCM and wanted one, the price is very good until I checked the postage cost of $70 on eBay.
Are you using it on a record that has been treatment with something like Last Record Treatment? I noticed that when I cleaned a record that was treated with Last that the solition beads like that.
The record was initially untouched. Only used solution with Triton. Also tried a different record with the same result.
If anyone could post a photo of their record with the solution spread around just so I'm satisfied I haven't got the wrong idea of what to expect.
I've also applied L'art Du Son cleaner and this spread like a sheet of water across the entire surface of the record, link to the product https://www.amazon.co.uk/Vinyl-Record-Cleaning-Fluid-Concentrate/dp/B007B1BLBI/ref=sr_1_1?ie=UTF8&qid=1464734344&sr=8-1&keywords=l'art+du+son
Go to this site: http://www.canuckaudiomart.com/deta...-rcm-3d-printed-parts-you-supply-the-shopvac/
Nick is advertising shipping to the US for les than $30 and I hazard to guess that is in our native scooter bucks so should be far less than $US and the EPray price ;-)
He is very easy to deal with and I really don't think you can find a better solution at double the price...
I got a brush like that one from Nick - didn't like it - got very soggy and was not as effective as the large format Home Depot paint pads for an even spread across the record. I think you will be surprised. Yeah, colour was not great but I really do like the band (from iceland) - Of Monsters and Men - great artists!
Status
