Record Cleaning: Developing the Best Possible Methods
Status
Not open for further replies.
I bought the Hepastat 256 from Quill to give this cleaning formula a shot.
One question, do you need gloves to work with the product?
Also, a recap of what I understand the latest formula to be: (Spin Clean tank = 24 oz, .1875 gal, 709.688 ml)
Phantomrebel, is your formula/process for making Enzyme solution something that you can share with us? If so, it will be greatly appreciated.
The discussion about mold release agent raises a question: earlier in this thread there was a discussion about Last record Preservative and soundgaurd - type solutions and how they are lubricants that we don't want on our records. Here we are talking about a layer of wax left on the record from the manufacturing process as a good lubricant to have on the record. So, what constitutes a desirable vs an undesirable lubricant? It is interesting that Last has a formula called Power Cleaner that is targeted at removing "mold release agent" but, you are supposed to add Last Preservative as a final step to preserve your records. Also, have you had experience with Stylast that helps protect and prolong the life of your stylus?
You will have to read the whole thread as it is somewhere in there. For example, the commercial conditioners like Last were covered in #168
They must be back in the market. I just purchased a 64oz bottle of Brighton Professional™ Hepastat 256™ Restroom Cleaner; Handy Mix, Dilutable, 64 Oz. from Quill and it arrived yesterday. Pretty reasonable price of $31 shipped.
Yes, they are making it again. Hopefully the formulation hasn't changed.
It's not toxic, but it doesn't smell that great so you could use gloves. I don't, it's nothing like bleach and more like super-concentrated hair conditioner. As to your formulas, they look OK, but remember the Spinclean formula contains a flocculant (polyaluminum chloride, I believe) to keep the removed debris in the bottom of the tank. Hence, when using a DIY solution without this you must change the solution often as debris is solubilized and can be ground back in using the device.
This is my formula.
I truly wash my records.
I use a stripped down TT in the wash sink and high pressure wash that rapidly spins.
I use my hand to apply the soap (free and clear laundry detergent) and back wash while the force of the water spins the record and also back wash with my hand against the flow.
Warm to hot water depending on how dirty the record is. The surfactants in the laundry soap gently cleans and doesn't bother my skin but rubber gloves could be used if that's a concern.
No need for a brush because the pressure removes everything and washes away.
Rinse both sides very well after removing from the TT, towel dry and use vornado fan for final drying.
There is not much contact time with the soap, mostly water and there is no need to use distilled water.
I can wash, dry and play in about 5 minutes.
The labels are very rarely affected at all as you can see in the photos.
No chemicals, just free and clear soap and copious amounts of tap water.
This works amazing for me.
Try it with an old junker sometime.
If you are really concerned about the label there are ways to protect it and keep the water away from it but I very rarely damage the label and there may be a few bubbles that go away once fully dry.
One word of caution, fingernails can easily scratch records so it's important to be careful while handling the record and I use static dissipating gloves for handling afterwords.
I have also begun using anti static bags for sleeves and have virtually no static issues.
A few photos of washing and after are attached.
Both of these records were very dirty and oily prior to this and sounded very clean afterwards.
IMG_3700.JPG IMG_3685.JPG IMG_3687.JPG IMG_3686.JPG IMG_3690.JPG IMG_3703.JPG
Thanks. If I use the spin clean formula I usually change the bath out every 25 records or so.
I haven't posted in a while, I have a 10L US, 2 Spin Cleans (1 for wash, 1 for rinse), and an Okki Nokki. Cleaning combos depend on how much time and patience that I have.
Thank you very much Rushton and Phantomrebel .....
The LPs I treated with SoundGuard 35 years ago still sound like new and there is no residue on my stylus under 1000X. If I could get it, I'd use it again.
I've stopped using LAST since I adopted "The Formula." I'm going to try washing one of my LAST-treated discs soon, as it was pretty static-filled when I played it last.
I read this entire thread last week in stages and then ordered Triton X-100 and 99% Isopropyl alcohol. I did see several posts about mixing percentages but now I can't seem to find it in this monster thread even after several searches. My stuff arrived and I'm ready to mix up. Can somebody please list the recipe for me again in simple terms? This will be Triton, alcohol and distilled water.
Thanks!
OK I'm trying to piece this recipe together. I'll mix the Triton at 10% with water and then at 10% again with the water and 10% IPA when ready to clean.
A real simple recipe is to add 1 ml of Triton to 53 ml of 95% IPA. Then add 946 ml of water to get 1L final of a solution containing 0.1% Triton, 5% IPA.
Thanks. I figured the only way to get a reply is to post something that needs corrected. LOL. Although what I posted from memory might be close.
I have been cleaning some used records that I just purchased. Some of the records have surface noise even after cleaning (potentially groove damage?). But, what is odd is that I hear the noise mostly from one of the channels. I know if the previous owners had set the wrong anti-skate, over time, it could damage the groove on one channel. But, then, you'd expect the damage to be distributed rather evenly over many records. Any idea what the issue might be? I am wondering there is a problem with my setup.
Interesting question. So are you saying that there is noise on one channel; but only in some areas, not the entire side? I'd like to hear the theories on this, too. I've always visualised a stylus set up with the VTA too high or the alignment off to one side digging into the passing vinyl like a cutting head. I suppose the latter would affect one side more than the other and be worst at the areas where the tracking error was greatest. But what do I know.
It is possible that, if the horizontal pivot of a table was not free, that some amount of inordinate pressure could be placed on the outer side of a groove. The would exceed what anti-skating would nomally be able to produce. If such resistance passes a certain threshold, a stylus may ride at a point where it is near to skipping. This could cause damage to one side of a groove, over what would be on the other side.
Now to complicate matters, the inner and outer sides do not contain left and right material directly. It is more complicated that that. Damage on one wall of a groove, as opposed to the other, would still tend to manifest on both channels of produced audio.
Enjoy,
Rich P
Enjoy,
Rich P
You're SH!#ing me! How do they do that? I'll have to look at my test record under a microscope.
I find that interesting too. Did Wikipedia oversimplify it again in their discussion of stereo vinyl records when they state:
"In this system, each of two stereo channels is carried independently by a separate groove wall, each wall face moving at 45 degrees to the plane of the record surface (hence the system's name) in correspondence with the signal level of that channel. By convention, the inner wall carries the left-hand channel and the outer wall carries the right-hand channel."
I always wondered since the needle can't move one way for the Rt. without moving the same way for the Lt.
Anyway, I tried looking at the channel ID tracks of my test record and I really couldn't tell. I was using a crappy 1000x usb microscope and I also looked at it with a 30x loupe.
No, they didn't oversimplify it. This is the way the stereo groove was cut after the earlier vertical-lateral modulation approach proved problematic owing to the fact that the vertical modulation wears faster than the lateral one. It's also the reason why one channel is phase inverted to ensure that the center channel (mono) signal is lateral, which also provides for backwards compatibility with mono records.
It think the confusion relates to that last point; with mono being cut laterally, out-of-phase modulation (L minus R, or the difference 'stereo' signal) is therefore vertical. It's a different way of thinking about how the L/R info is cut into the groove.
Thank you very much for your inputs. I need to dig into this a bit more. I will thoroughly check my setup again and maybe try a different cartridge to start ruling things out.
On a different note, the images below are from two different brand new sealed records that I just purchased. Any idea what these white residues (not the dust particles) might be and how you get rid of them?
I see the 'aurora borealis' as in the top image all the time. It never washes off; but never seems to have any audible effect, either. I'd be interested if anyone can explain it. The lower image is unfamiliar.
Thanks you for the response. I see the contamination pattern similar to the lower picture in used records quite often. I always assumed that it was due to poor care, until I saw it in this sealed record. I have not been able to successfully remove it.
Status
