Record Cleaning: Developing the Best Possible Methods
Status
Not open for further replies.
I can't say there is any difference between the Hepastat and the Virex II for record cleaning. Both help with static for the first three or four plays then it seems the action of removing and inserting the record into the sleeve (MFSL in my case) causes some static.
This has been my experience as well, but I'm using the 3mil HDPE sleeves which seem to generate some static. I was under the impression the paper in the MOFI sleeves was supposed to reduce or eliminate static buildup.
Maybe I need to look at the grounding of my system. Right now my tonearm cables, with a separate ground wire, got to my SUT, then tube phono pre, then to my preamp. The separate ground stops at the SUT. I never worried about this because I thought the L & R grounds were summed with the external ground wire. Maybe I need to add a ground between the SUT and the phono preamp?
You could, but I doubt it would make any difference. Both my setups are independently grounded to the preamp, yet I'm still experiencing the reduced effectiveness of the quats over time. On both decks the records are swept by a CF dust bug as the record plays; one's grounded and the other not....doesn't seem to make much difference either way.
I'm thinking of trying a dilute alcohol/water/quat solution applied to the vinyl via a Last applicator brush. Do this when the static starts to get out of hand. Don't know what the consequences would be after several applications.
Thanks for the insights on your experience grounding your gear. I have an LP Gear carbon fiber/velvet brush I use before every play and I mist it first with a very dilute mix of Hepastat and distilled water . I helps reduce static and the moisture helps get any dust that might have landed on the record. I have washed my turntable's mat before but maybe doing that with a mix with a higher concentration Hepastat/Virex II might help. I have some 1:256 in a spray bottle used for household cleaning that I will try.
That's interesting. So, you're saying that even with a little treatment before each play you're still experiencing diminished static control after a few plays?
I'm beginning to think that an air ionizer situated near the TT is the only way to really break the static problem. I know a couple of guys that do it, but the air quality near the TT smells pretty toxic. :eek:
Not static related :)
Just wanted to pop in at the suggestion of Rushton about my experiences with US cleaning and using the Triton/Hep/Iso fluid.
The US bug was planted in my ear about a month or so ago. As a librarian, when I find out a little about something new, I end up deep diving into the topic, which is what I did with US cleaning. I read this entire thread, I read the mammoth thread on DIYaudio. The threads on Audiogon. Oh, and the thread on the VPI forum. I read independent articles and reviews. Basically, I drove myself crazy with US cleaning info. But I did it because if I were to invest the time and money, I wanted to do it right. So what did I do?
Basically, I ended up following Rushton's setup and procedure. Bought myself a US tank (I really wanted to go 60mhz but the price difference was just too great for what I came to understand were perhaps negligible results). Then I bought the VinylStack only with a modification. I read in one of the forums that if you are using a 40mhz tank, the recommended spacing be 1.5", so the kind folks over at VS helped me out with custom spacers and now I can clean 3 at a time with 1.5" spacing for 4 at a time with 1" spacing. Next came the Triton, Hepastat, and Iso fluid concoction. And thankfully I have a Whole Foods right down the street, so getting quality DI water is easy peasy and cheap. Oh, and I also rigged up a filtering system.
So, how is it working for me? Well, pretty pretty prettttty well. After a few beginner mishaps with fluids and stuff, I now have it down to a nice little system. I like to clean 12 records at a time which I can do in about an hour. The results have been nothing less than amazing. Visually, I can't imagine the records looking any cleaner. Sonically, the improvement is markedly better. Where there was once some background noise or odd click, now there is virtually nothing. The blacks are black if that makes sense. Things sound cleaner in every facet of the word.
I just want to thank everyone who has posted here and the other boards for giving advice, tips, and feedback to all of us who are lurking in the background :) These threads have proved to be extremely valuable and I hope to learn even more!
I wish my experience was the same. I found it was great on lightly soiled records, but scrubbing still does the best job on the tough ones, IME.
Might've been the GP 40kHz tank; apparently 60kHz and/or multiple variating frequencies is the cat's meow for vinyl. :rolleyes:
I have the 40kHz tank and the Vinyl Stack kit. I have had the same results as caseyjames (see above). Just about the only undesirable noises I hear now are from groove damage and/or scratches which US cleaning cannot fix. However, the pops and ticks from scratches are now less annoying because the other pops and ticks from stuff in the grooves is gone. It makes the light scratches on my VG or GD+ more listenable/acceptable to my ears. Groove damage sadly cannot be improved.
Um, this is going be embarrassing, I think. I now have my 64oz bottle of Hepastat 256. But i can't figure out how to work the bottle. Under the cap is another cap with two holes. That cap is spring loaded -- you push it down and it pops back. But it doesn't do anything. I was thinking it was a pump or a dosing mechanism, but it doesn't do anything. I can tilt the bottle and squeeze and nothing comes out. Do I need to pierce that two-hole inner lid (I took off the inner foil already)?
Seriously, this pretty embarrassing that I can't figure out how to work a cap for restroom cleaner. But I can't. Anyone willing to point me in the right direction?
That dispenser mechanism is all connected to the plastic cap on the spout. I was able to pry it out with a screwdriver and the whole mechanism lifted out with the cap.
This is true, however, I have a CAUTION for anyone who tries this. Wear eye protection or a full-face mask or something.There's potential for disaster. I experienced it. I'll follow up with details later. But wanted to get this caution up here NOW.
A spiral-fluted countersink bit put two small holes in the gizmo. Works well to measure small amounts out easily.
Thanks! Sorry for the late PM reply.
Update: This stuff is nasty and the bottle is DANGEROUS.
Like many here have done, I tried to pop out the inner lid as others have mentioned. But somehow caused a high-volume woosh of hepastat to the face as the thing popped out. Probably 8 oz directly to the face. Immediately ran to shower and rinsed, which likely saved my vision. Spent the night in the emergency room getting eyes flushed with some medieval torture device, followed by scoping and prodding and various vision tests -- they even called in the attending ophthalmologist to double check. Now I get to spend my vacation healing from burned eyes. Luckily, though I can still see! The burns shouldn't be permanent as long as I can avoid an infection.
While this stuff is safe compared to, say, bleach or tilex or scrubbing bubbles or whatever DIY solution you're using, it's still dangerous. It can blind you. Luckily not as fast as bleach, but it's a real danger. Anyone messing with the bottle in concentrate form should be wearing full face protection -- goggles are a good start, but I'm here to tell you it's pretty brutal getting it up your nose, too. I had been wearing safety glasses but I took them off "for a second" because they got a smudge on them. Don't do that. PROTECT YOUR EYES!
Side note: Coast Labs/Staples needs a better bottle design or instructions on the bottle or something. This thing is dangerous!
All professional cleaners need to be handled with care! Sorry to hear about your experience, but it helps people be aware of this. It's similar to splashing Simple Green or Lysol in your eyes. Even the IPA we all use is dangerous in this regard. Why some Hepastat packaging has a dispenser to deal with I do not know.
Yes, embarrassing to me, but I thought it was worth sharing. Diluted hepastat is apparently not a big deal (even at the 256 concentration), but at full strength it'll get'cha. That said, regular old bleach would have been even worse. I'll reiterate the packaging conundrum. If it ONLY works with a certain type of system, it should say so (and have instructions) on the label. A real lapse on the part of Staples/Coast Labs.
Status
