.... leaching from vinyl records from my experiment and experience is totally a non issue unless you are using some crazy mad solvent...
Chris
Interesting test, but this conclusion goes against scientific evidence. As any compatibility chart will show (e.g.
https://www.calpaclab.com/pvc-polyvinyl-chloride-chemical-compatibility-chart/), many of those solvents (e.g. acetone) have severe effects on PVC-based polymers. Furthermore, extraction of chemicals within PVC-based products have been measured (using MS-HPLC, for example) with even mild solvents like alcohol at concentrations over 60%. So while the record may appear and play OK, it certainly is different than the original composition. Could be fine for common or short-term records, but the idea behind this thread was for long-term preservation of collectables. Records are chemically tough, but like all plastics, they do have a useful life span. This life may be over 100 years, and I wouldn't want to shorten it doing things that might not be fatal, but are scientifically known to be harmful. Same reason I don't smoke, though I don't judge those that do.
doing my first batch with hepastat today, mixed 7.5ml hepastat, 30ml iso and 30drops tergikleen for a 2gallon US run.
i THINK the math works out on that, ive seen different mixtures most are for a bigger concentration.
You are good with the Hepastat (your doing a 1:1000 dilution resulting in a little over 0.02% quat, which is within the suggested range). I can't say on the iso as you don't say what stock % you are starting with. Likewise,I don't know what conc. Tergitol is in that product. Let us know how it works out!
A few questions:
(1) Chemically, what is the difference between Ilfotol/Photoflo and Triton-X?
(2) Are the small amount of bubbles/foam next to the records when using Triton-X a cause for concern while cleaning? Are the suds that develop while the pump is working a real problem?
It would be helpful to settle on one of the chemicals, and then by trial and error discover the minimum amount that is necessary to encourage the drying of records. My best guess is that for one-step cleaning and drying, without the use of a water rinse, the best combination might be a chemical that is primarily a wetting agent, like Ilfotol, combined with alcohol. Triton-X appears to also be a detergent, and thus less appropriate for a one-step clean and dry process??
This has been addressed many times in this thread, but in summary:
1.Photoflo contains a non-ionic detergent (5-10%), but is mostly propylene glycol (25-30%). The glycol is a problem. Ilfotol is better, as it only contains the non-ionic detergent (they don't specify, but it is an alcohol ethoxylate, exactly like Triton). Problem is it is only 1-5% detergent so you are paying dearly compared to pure Triton.
2. Small amount of foam is a good thing. You can reduce the concentration of the detergent if it becomes bothersome. That said, there is no excuse for not rinsing a record after deep cleaning with any detergent. It is an important step as folks here have attested. Also why aren't you using a quat in the mix? I know Rushton uses them as I gave him the recipe. Finally, if drying is an issue, you might want to invest in a vacuum RCM. This will allow a quick rinse step after the US and greatly facilitate drying...win-win!
