electroking
a- v- karma member
You do have to admire the ingenuity of some of the builders around here, that's probably one of the nicest fuse poppers out there!
I always wondered what the design process was on semiconductor devices that had to be bolted to a metal surface to dissipate heat, but would blow up (or blow stuff up) if allowed to actually touch that same metal.
This statement is hard to follow. Coupling the semiconductor chip to the
metal case is a good way to remove heat, putting the insulator inside
the case would just mean the dissipation would have to be lowered.
