Absolutely +1
With Jomark's really in-depth knowledge of Sansui, and the eternally positive attitude of OJ - who could want for more...
Not forgetting the fantastic help I have had from you Ron
OK sorry
Did you exchange the cap below for new or upgraded the one on the other side / top side of it?
Also, any info on the caps you used to replace the four big 25v 4300 originals on the 2781 power protection board?
Finally, I noticed that you replace a couple of diodes on the 2781 board. Info please?
Oh yeah...forgot to ask...
Any details possible on the Kuehne ground modification?
More details on this and its effects would add quite a bit to the X1 knowledge base.
AND
"Temporary short on both -11v supplies, caused by star ground solder tag bent to wrong position"
Any chance of pics and details of this problem and its solution?
THANKS!!![]()
I performed the modification to the Flat Amp board almost exactly as shown by Harold with his 3 stage picture of how it should be done. The capacitor between the grounds on the Flat Amp, I connected right on the signal ground posts (at the end of the Flat Amp PCB), and then used thick stranded wire to connect the additional 2 capacitors to the earth tag - the now infamous tag described in the '-11V problem' below.
The way I see it, when you have grounds on PCB's in a fast amp like this, they have to be connected in as close to a 'star grounding' system as possible, or otherwise in a series fashion to avoid ground loops. Inevitably noise 'pickup' from various sources inside and outside the amp will cause some grounds to be noisier than others which, with the high gains and extended frequency response present, this could (and does!) cause instability. The choice of decoupling capacitor 'value' and 'dielectric' is very important here, and I think the choice of 10nF (10,000pF) capacitors is indicative of the high frequencies being dealt with by this modification. The installation of three capacitors, one to effectively short the Flat Amp grounds together, and 2 more to shunt both Flat Amp grounds to a star ground, is unusual in my experience, but I believe I can understand why it was done this way.
Not a lot to see or describe really, I had bent the tag, (located on the chassis member in between the driver amp modules and the phono amps), upwards to tighten the screw I think? - and had forgotten to bend it down again. This meant that when I re-installed the phono amp boards 2 of them shorted on this tag and caused the problem. 2 minutes to find the problem and 30 seconds to reform the tag - done.
I replaced these capacitors - the 470µF (topside) and the 330µF shown below like for like - the underside 330µF is now much smaller, more neatly soldered and positioned. Replacing with one capacitor ?? - who has 800µF capacitors 'on hand'![]()
