adnick
Addicted Member
Made some progress today, this is a rough cut out of the first layer plate, it rides directly against the top plate….It clears all the internal mechanisms and the electronics.
This first layer is thick enough to allow the motor plate movement, this will allow for a more enclosed second layer, the open end will have to remain open for several layers, to clear the “gear shift” mechanism. Eventually the layers will only have a hole for the motor, and ventilation.
Next step, use this rough cut out as pattern for a cleaner example, and then start adding layer after layer….
but it’s certainly not rocket science
