Dropped the old Russco in the plywood inner plinth, added an S220 tonearm with an AT cart on the original metal arm board.
Using an ST70 and slightly modified PAS 3 to do the test, keep in mind nothing has been done to the Russco…
Speed was good so played some Sinatra just to check sound, actually sounds good
One thing to note, it had a bit of hum and yes the tonearm was grounded, not much but had to investigate.
The solution was to add plastic washers above and below the metal arm board, after that the hum was gone
Next was to use a test record with a silent track to listen for noise, have a few test records, and unfortunately one may need to buy more than a single test record if you have other test equipment that uses other tracks on the record to ensure all tracks work as required.
Tried several different platter mats, they do make a difference, the combo of a Herbie’s 2 & acrylic mat.
Also have noticed that certain tonearms/carts can cause noise, so I always test with more than one. And yes at higher volumes there’s idler noise, it started as audible to the ear, remember it has the old idler, mounts and such.
When it was making an audible sound, I noticed the motor drive shaft (capstan) was rusted, a few different passes with sandpaper and rubbing compound solves this, but it’s still there at higher volume with the silent track…
Changed the tonearm to my ESL 1000, all original with the Bakelite headshell and Shure M3d cartridge! Have to give a huge thanks to
@BillWojo for making a new aluminum base; the original Bakelite was fine but not substantial enough to securely mount the arm without some additional stuff.
Bill did an amazing job, the tolerances are perfect
Will leave it with the idler noise for now because it make a perfect candidate to test our plinth design….
Next test will be with the plywood plinth installed inside the Black Walnut plinth and we’ll see if that reduces the noise any. After that we’ll add the layers and again note the results, if the plinth functions as advertised/planned then there should be an overall reduction in noise even before the table is rebuilt!
Here’s the plinth assembled for the next test….
