SA-9500 II Switch Assembly AWS-109 Transistor Replacements
rd48sec
What are the replacement transistors on a AWS-109 Switch Assembly board (SA-9500II)
Q8 2SD526
Q9 2SB596
Q10 2SC1318
Q11 2SA720
Q8 2SD526 use KSD526YTU
Q9 2SB596 use KSB596YTU
Q10 2SC1318 use KCS2383YTA
Q11 2SA720 use KSA1013YTA
Make sure to check the pinout before installing when using replacement transistors.
