I have a sansui 5000 not an a or x version. It is in very good condition cosmetically but needs a full restoration. That speaker looks awesome do you have a stereo pair? What will you use them with?what are you working on?
also the Top solder point on the left picture middle (R815) is actually soldered to the red/orange top with a white wire on my 6013's
Mine is a 5000 only so we have close to the same I think.Thanks for the info. Apart from replacing these boards and replacing all the electrolytic caps is there any other components I should be looking to replace as a matter of course? Which model is your receiver?
Note: this unit is up and running, just waiting on cosmetic work.
The white wireNote: this unit is up and running, just waiting on cosmetic work.
I actually have an original single Karlson I use on my 66 Packard bell consoleI have a sansui 5000 not an a or x version. It is in very good condition cosmetically but needs a full restoration. That speaker looks awesome do you have a stereo pair? What will you use them with?
Thanks that is one less bit of confusion…Your white wire is connected to the same copper trace as the wire from the fuse, so that attachment is essentially equivalent.
No jumper is used between channels with replacement F-6013 boards, whether they are genuine Sansui or reproduction boards based on what I've seen. As I believe I said the jumper between channels is based on pictures of 5000X where the 6013 boards were installed at the factory. Don't know why but it's most likely that junction just needs the voltage delivered from the fuses. I would not add the jumper between channels, I never did and have successfully refurbished several units with both reproduction and genuine Sansui boards.
No thermistor on my unit. I think that only applies to the 5000X.Yours seems to be the R01150 model as it has thermistor on the back plate. I wondered how that would look
