Sansui AU 20000 restoration - many... many pictures
Kale,your work is truly an inspiration for all of us :ntwrthy:
Are you sure you don't need an apprentice :D
Kale, if a picture is worth a thoasand words you are a master story teller. Thank you for sharing the restoration.
I wish I had time to learn this kind of work, it is very interesting to me
thanks for sharing your talent and for preserving these classic pieces that need to live for another generation to experience.
Haven't read the whole thread yet, but wanted to say to Kale that I have two different reg ps boards here and a couple of AU-20ks that have the output stages soldered on instead of the gold plug in pin assys.
I have had one BA3000 which has output stage wires soldered on the Motherboard, but until now I didnt see that on some AU20000
We also know there are two different output stages, 1 with bias transistor on it, 1 without. Same for the driver boards, where the bias transistor moved from/to.
The same thing on that BA3000 was with bias transistor
@ DVNOBLE
YOU did great job, all those resistor changed by you is really a big work!
But I have some questions; why you didnt change trimmers on driver board, or as I can see you changed trimmers on one driver board, but with some open type. Those trimmers are so important (BIAS and DC Offset), so it will be the best if you use some multi-turn type.
And as second; why you didnt change those serial diodes with 1N4148 ?
Nice work Kale, looks like the previous "technician, or butcher" used whatever screws they had lying around to secure one of the output transistors!!
I like the work you do to clean up the circuit boards, dismantle and clean the switches....
I also like those emitter resistors you are using.......
Thank you!
Those emiter resistors are 12Watt MILLS non-inductive resistors, and I like to use them at Sansui amplifiers - receivers
OK, some more pictures....
The Tone Control Board
Potentiometers ready for cleaning
is it like new now :)
Output Selector
Sansui used two the same wafers for each contact to reduce crossover resistance but it is really hard job to dismount the both wafers to clean them
you see now about what I was talking above:
ready for cleaning
again like a new :)
and connected back to its place
And now, Tape Copy Selector... but first you should see this
this is one unused pin of that selector, but it is bended on wrong way :no:
To dismount that selector, you should remove all small signal cables
very demanding job...
finally it is out
here you can see how it was looking
the both wafers ready for cleaning
and like new...
Kale, your work is so astonishing - sometimes it seems like you have brand new replacement parts (PCB's Switches etc) as the clean up job you do is so thorough.
Thanks for posting the story :thmbsp:
again cleaning.... cleaning... and again cleaning.....
here I have found a problem with Balance pot... it had a bad contact, but it is not simple to dismount it, look at the next picture :
the axle of potentiometer is nailed, and you should remove just only small part of that, just enough to separate the axle from other part of potentiometer.
Here you can see all parts of Balance potentiometer
Now it is clear why it had bad contact
and again reassembled
and here it is, like a new :)
Man, somebody farked that amp up good. Just a shame what was done to it, and a blessing you ended up with it.
Where you get the NOS outputs?
Thank you John... but each day is harder and harder to do like these things, my eyesight is getting worse, so I do not know how long I will doing restorations on Sansuies...
Ok... the small signal cables are soldered back to theirs place
and now light of power meters...
as you can see, the lam was not like it should be, old lam was 6.3V, but it should be 7 V
the new correct lamps installed
The story is closer to the end, now I am tired, so I will post the last pictures tomorrow, so... stay tuned :smoke:
Hey Kale.........absolutely marvellous job! I was studying your pictures in post #32. On the meter circuit board......how did you orientate the capacitors that were in the wrong way? I noticed that you put 2 caps in the 'wrong' way and 1 cap(C03) in the 'right' way.....how do you know which is correct? The board.....or the cap? Which way do you trust?
GREAT JOB and GREAT STORY!
