The right way is how it was working 30 yearsI was studying your pictures in post #32. On the meter circuit board......how did you orientate the capacitors that were in the wrong way? I noticed that you put 2 caps in the 'wrong' way and 1 cap(C03) in the 'right' way.....how do you know which is correct?
GREAT JOB and GREAT STORY!
I hope you enjoyed... until some next interesting restoration, I wish you all the best all of you :thmbsp:
Kale,
I can't imagine the time it must take to disassemble, clean, repair and reassemble the individual components as you've done in this restoration. I'm also curious how much you spend on contact cleaner! ; - )
Was this for a customer, or is it your own amplifier?
I'm glad that you resoldered the solder thru-holes on the those heat sink mounting boards as mine had a real nasty problem that was make it go DC intermittently when first turned on from cold and ended up being bad solder joints on those double sided connections. That was the worst part of the whole repair as it tended to blow the outputs if you weren't quick enough!
i have two questions if you dont mind.
what kinds of cleaners did you use on the boards, and what kinds were used on the contacts and potentimeters.
I know that at newer Sansui amplifier, you can find Elna Silmic capacitors, so at audio path, I like to use ELNA Silmic and Nichicon MUSE (FG and KZ series) capacitors (if I dont have Silmic), for bipolar electrolytic capacitors, I like to use Nichicon ES capacitors...Also, i noticed that you used a variety of different kinds of capacitors in this restoration. how does one decide on what type of capacitor is best for what location?
