Progress was made today. The current state had been that I was getting about 35V DC offset at speaker terminals. Both channels seemed to be affected equally. The only configuration that gave a difference in the two channels was with F005 and F006 pulled and no driver boards in. Then I was getting offset of -24V on L channel and 0.3 V on R channel.
So, in this configuration with pre-out and power-in separated (jumpers pulled and speaker output set to C) I swapped TR855 and 856 (2SA566) to see if the higher DC offset from L channel would move to R. No change. Then swapped TR853 and 854 (2SC680). No change.
Next decided to measure the pin voltages for all connectors with the driver boards out on both channels. Significant differences marked with an arrow.
Pin, L, R
P, 51, 51.9
O, 0, 0
N, 0, 0
M, -1.7, 0.17 <--
L, -1.6, 0.18 <--
K, -1.7, 0.26 <--
J, 42.7, 42,7
I, -4.3, -4.0
H, -27.5, 0.9 <--
F, -42.2, -42.0
E, -42.7, -42.4
D, -0.16, -0.5 <--
C, 0, 0
B, -50.2, -49.9
G, 0, 0
A, 0, 0
So, MLK are BCE of TR853; however, since I swapped TR853 and 854, I focused on TR857 since K is also base voltage for this transistor and H is connected to the emitted through a cement resistor.
Took ECB readings on TR857 and TR858 for comparison:
TR857, -42.2, -28, -42.5
TR858, 0, 42.6, 1.06
Seemed like TR857 was bad (Sony 2SD88A), so pulled that and replaced with the one good 2SC1079 I had on hand. (I tested the Sony with my transistor meter, and it tested ok.)
Turned back on and 8H is reading 0V on both channels.
Decided to put fuses F005 and F006 back in, still getting offset of 0V.
Decided to put R channel driver board in. Got 27V at speaker C out.
Took the same driver board and put in L side, 27V output but then R839 smoked.
That resistor connects pins F and E, which is B9 power supply and TR855 C.
Realized I probably should have checked all pins for driver boards before putting the board back in.
So, with F005 and 6 back out, checked all pin voltages.
Pin, L, R
P, 49.1, 49.2
O, 0, 0
N, 0, 0
M, 4.2, 0.16 <--
L, 4.2, 0.18 <--
K, 4.4, 0.24 <--
J, 40.5, 40.7
I, 27.9, -9.0 <--
H, 39.4, 0.76 <--
F, 39.5, -40.2 <--
E, -40.5, -40.5
D, 39.9, -0.9 <--
C, 0, 0
B, -47.5, -47.8
G, 0, 0
A, 0, 0
So, MLK are BCE of TR853/854 and IFD are ECB of TR855/856.
I'm at the point where I think all of these transistors along with OT need to be replaced. They test ok on my transistor test meter and do not test shorted on my DMM diode setting, but these voltage readings do not look good. What are the replacements for TR853/854 and TR855/856?
On the positive side, all of the PS voltages have come down from before changing TR857.
I also assume that it is not OK to use 2SC1079 in TR857 and 2SD88A in TR859 as these are differently rated transistors? Probably should have thought about that before putting the driver board in on the L channel.
Pin, L, R
P, 51, 51.9
O, 0, 0
N, 0, 0
M, -1.7, 0.17 <--
L, -1.6, 0.18 <--
K, -1.7, 0.26 <--
J, 42.7, 42,7
I, -4.3, -4.0
H, -27.5, 0.9 <--
F, -42.2, -42.0
E, -42.7, -42.4
D, -0.16, -0.5 <--
C, 0, 0
B, -50.2, -49.9
G, 0, 0
A, 0, 0
Pin, L, R
P, 49.1, 49.2
O, 0, 0
N, 0, 0
M, 4.2, 0.16 <--
L, 4.2, 0.18 <--
K, 4.4, 0.24 <--
J, 40.5, 40.7
I, 27.9, -9.0 <--
H, 39.4, 0.76 <--
F, 39.5, -40.2 <--
E, -40.5, -40.5
D, 39.9, -0.9 <--
C, 0, 0
B, -47.5, -47.8
G, 0, 0
A, 0, 0
