I finally finished up my G22000 this morning, I had already done a lot of work, a full recap, new relays, trimmers and some transistors etc etc.....
But I liked what Matt was doing with the signal path and some improvements on the driver boards so I did those too.
I have had a listen to it, and it actually makes quite an improvement, more image depth, and better resolution at high volume.
The bass was more prominent with nice sustain but improved clarity. The EQ actually shifts the phase 180˚ which is interesting, but I think the EQ sounds better than before if you have to use it.
I use 6Ω nominal JBL L7's with my G22000, and it is happy to crank along with up to 300watt peaks on the meters, no problem at all, I played it for over an hour like that, so if there is any questions about whether these amps can drive those sorts of loads or not, well, I say they can.
If anyone has a G22000, I highly recommend following Matt's thread here and do those cap upgrades....
Here's a pic of the frequency vs phase. The small less than 1/2db loss at the top, could be my sound card, I am not using my usual one, so I am not sure of its performance.
