Interesting question.Curious, add another set of bjts to the o/p, using the same part type? 2SA909/2SC1586 (200V,15A,150W,10MHz ft) or change them all for or similar. big power difference MJ21193G (PNP)/MJ21194G (NPN) (250V,16A,250W,4MHz min ft)
My G22000 has MJ15024/25 in it anyway, so I'll add another pair of those....As usual, nice work and thread Matt
MJ21193G (PNP)/MJ21194G (NPN) (25V,16A,250W,4MHz min ft)
I might have argued to keep it original, but I hadn't owned one at the time and didn't realise what a pain that protection kicking in early was.Ohh i know John.
I wasn't referring to you.
I've done it with a great success. I'm the first who did this mod along with 33000μf on each rail per channel on my G22K and it still sounds very good . Along with some other mods.
Hilarious amount of power output!! I found mine to be about the same.
What I plan to do to mine is to install another pair on transistors on each channel as there is the space for it, I think it will help with delivering more current when the impedance dips low as I am sure it does on my JBL L7's...
When i said about doing the same thing on mine there where serious doubts and disputes , from some guys here.
Hehe .
Much more difficult to accommodate the extra transistors because of the internally bridged design. The G-22000 uses 3 pairs of OP transistors per channel - so you can add another pair per channel with advantage quite easily, especially as the physical heat sinking allows it. But with the AU-D11 II, which has 2 pairs of OP transistors per channel (1 pair in each bridged amp) you would need to add another 2 pairs to each channel - thus doubling the total number of OP transistors. Obviously space to accommodate them is going to be a problem in this case.I am assuming this won't be possible on a bridged amp like AU D11 mk2?
Hard to say, what you get is the upgrade transistors sharing some of the load, the amplifier being able to deliver more current as a result. Obviously this requires more current from the power supply, so upgrades to main PSU filter capacitors will help up to a point, as the transformer will usually be overspec'd enough to deal with the extra demand. The individual OP transistors will be less stressed, but total heatsink capacity will begin to be a factor with prolonged high power output.And what do more outputs per channel do for the sound?
Oh my word yes it does!! I had the same experience, I thought something was wrong with my Distortion analyser, I actually checked it as I could not believe what I was seeing.....Its an extraordinary tuner....easy to align.....I like the way the Zero adjust works on the tune meter, "move the stub".
Yeah agreed, the rest is pretty easy and it responds well to adjustments...
Awesome write up Matt.....![]()
There is a short piece of wire with a piece of heatshrink over the end, from memory I think its a yellow piece of wire, you move it around until the Meter is Centred.I am working on a G-22000 and came across the term "move the stub". Are they talking about the actual meter, making an adjustment to it? Actually the entire first section of the alignment is a bit confusing. Normally I would use the discriminator coils to center the tuning needle and get the lowest distortion. How did you do it?
Thats the one, interesting, the one in my unit is yellow, makes it easy to find.....they must have just used whatever off-cuts they had lying around maybeThanks for the tip.
After looking at the service manual I can see the "stub". It's just a small piece of brown wire about 1 1/2 inches long with a fold of friction tape over the end of it.
At the moment I am just evaluating the unit. I plan on doing a tests on it before and after alignment. Then I will replace the caps and align it again and repeat the evaluation.
C01 and 03 along with C02 and C04 form a 5uF "bi-polar cap" and is bypassed with a .047uF mylar film cap (C05 and C06). These were replaced with a single 4.7uF Panasonic ECW polypropylene with a jumper placed to allow for maximum lead spacing to accommodate the big poly cap. C05 and C06 were removed.
When you see two electrolytic capacitors in series, connected '+ to +' this is simulating a single bipolar electrolytic capacitor. (rated at double the voltage and half the capacitance of the individual capacitors, so if you have a 10µF + 10µF combination, each rated at 25Volts to make up a bipolar electrolytic the resulting value is 5µF and voltage rating of 50Volts).is there a way or “rule of thumb” to identify such double-cap setup to simulate a bipolar?
Now however, high quality 'single can' bipolar electrolytic capacitors are available in a range of values suitable for use in these situations. If the value of the combination is low enough, you can use a film capacitor to replace the electrolytic 'double' or 'single' bipolar, i.e. less than say, 5 or 10µF. However this should not be taken to extremes, size is a big consideration (pun not intended), and the replacement should fit comfortably in the space occupied by the original, not impede airflow, and not strain the tracks of the board due to excess weight. If the replacements are getting too big - to the point that their leads need to be sleeved to prevent short circuits, or they need to be supported while you solder them, this is the point to reconsider whether a single quality bipolar electrolytic is a better choice.Are they always replaceable by a single capacitor (size permitting).
If the original bipolar electrolytic was also bypassed by a low value film capacitor, (0.047µF ?) this can usually be removed, thereby giving even more space for a suitable replacement for the entire combination.
The bypass is used to even out the frequencies that are passed (helping with the higher frequencies), which has the effect of overriding the less desirable characteristics of the 'electrolytic pair' bipolar.Why is the bypass there in the first place? What makes it "removable" once we have a single capacitor?
I can't help you with measurements, but I am sure in a restore thread somewhere the diameter and height are noted. Regarding value increase, there is no need to increase the capacitance value. However it might prove useful to upgrade either the value or the working voltage of the replacements slightly to increase the physical size of the replacements for a better fit. As you may know today's replacement capacitors tend to be a bit smaller than the originals - so a physical size increase can make for a 'better fit'. I think I have seen units with 22,000µF replacements, I am not sure what rectifiers are used, but an increase such as this should prompt a review of the rectifier capacity.Does anyone git the measurements for the big 15000uF cans?
I´m physically separated from my unit and would like to order parts to restore it.
Are there any needs to raise the capacity of those capacitors?
