Sansui relay subs
Note however that the links point to the 12V versions of that relay - we would need the 24V version. ;)
Couldn't a DIP package DPST reed relay be used mounted on a small piece of Vero board wired to fit into the existing relay holes on the PCB?
How many way to skin a cat.
Any chance of a link to demo of this being done??
The idea of this thread is to pull together a quick and easy reference for finding modern replacements for old relays in Sansui devices. I will pull together what info I have, but please everyone contribute what you know and I will continuously edit this first post to combine all of the data.
Please provide (where possible) Sansui model / sansui part number (if you have it) / modern part replacement and note any mods required. I will link each model to either the relevant post in this thread, or a relevant thread, whichever holds the most info.
Sansui 8080: MY4-02-DC24
Sansui 9090: MY4-02-DC24
Sansui 9090db: MY3-02-DC24
Sansui AU-517: MY2-02-DC24
Sansui AU-717: Taiko RABK 2B --> MY4-02-DC24
Sansui AU-9900 / 9900A: Omron #MY4-02-DC24
Sansui AU-11000: Omron #MY4-02-DC24
Sansui AU-20000: LY2-0-DC24 (x1); MY4-02-DC24 (x1)
Sansui AU-X1: LY2-02-DC24 (speaker x2); ? (Soft Start x1); G5V-2 24DC (Signal x5; need leg extensions); 24V DC reed relay --> Omron G5V-2 24VDC (Headphone 1x - not direct drop-in but easy job)
Sansui BA-F1: MY4-02-DC24 (speaker x2; cut off 'NC' pins x4 as no holes in PCB for them).
Sansui G-4700: none
Sansui G-5700: 1150400 or 480 --> MY4-02-DC24
Sansui G-6700: 1150400 or 480 --> MY4-02-DC24
Sansui G-7700: 1150400 or 480 --> MY4-02-DC24
Sansui G-8000: see G-9000.
Sansui G-8700DB: 1150410 --> LY2-0-DC24
Sansui G-871DB: 1150410 --> LY2-0-DC24
Sansui G-9000: LY2-0-DC24 (speakers x2); MY4-02-DC24 (protection x1); MY4-02-DC24? (headphones & power meters x1).
Sansui G-9000DB: see G-9000 (restoration showing relays)
Sansui G-9700: 1150410 --> LY2-0-DC24
Sansui G-971: 1150410 --> LY2-0-DC24
Sansui QRX-7001: 1150101 --> MY4-02 DC24
Has there always been a time limit on editing ? I can no longer edit the first post of this thread.
So updating below - adding AU-217
Sansui AU-217: Speaker relay --> MY4-02 DC24
Sansui G-4700: none
Done. First post edited. If anyone has relay subs to share, please comment here and I will add. I'm sure I've missed many.
Funny story. I can't go to the office today for work because I tripped over the new CA-F1 that arrived yesterday. I left the box in the living room and forgot it was there.... 'ass over'. Just a stubbed toe really... but I came inches from landing my face on the AU-111. That could have been worse!
Both my G7700's do not use this MY4-02-DC24 relay.
They use some miniature fujitsu thing, different pinout to the MY4 as well.
There is no relay I could find which fits the pinout and holes in the PCB, so I mounted a new relay externally near the regulated supply board on the chassis.
Thanks Kev, I will put a big fat question mark next to the G7700 info and a link this post.
I still have the old relay, I'll get it out and at least post the OEM part number here so if someone else wants to see if they can find a solution they can do so.
So both of the F-2980 boards in your G-7700s have different tracks and pinouts than most of the F-2980 bds we have looked at? I'm wondering if there are any other differences. ?????
Here is the relay from the G7700 (Later Model). Not a LY or MY. Not an Omron, best I figure is its a Fujitsu...or no name brand!!
The Middle pair of terminals are the Coil, which eliminates a lot of modern replacements.
Maybe someone has the time to do some research, I drew blanks on my search.
View attachment 1248846 View attachment 1248847
Thank again kev. Linking in the first post of thread. Hopefully someone will dig up a sub, or maybe can outline instructions for a mod.
