+5V Power Supply
This is pretty simple, pump in +14 volts, the IC only let’s out +5V. It’s a voltage regulator. Unfortunately, to do this, it dumps voltage by consuming amps and producing heat. But, they’re a cheap way to get a regulated voltage.
Here’s the Sansui one in the XR-Q11:
The +5V power regulator is on the left, the FS7805M, fed by a +14.3V line from the power supply.
The -5V power regulator is on the right, the FS7905M, fed by a -14.2V line from the power supply.
For the moment, we’ll ignore the -5V since the +5V is the only one used to power the Sensor E/F electronics. Interestingly, the +14.3V line that feeds the +5V supply has a couple of extra stages of filtering compared to the -14.2V feed for the -5V supply. But we’ll ignore, that, too, for the moment.
The FS78xx and FS79xx series are very likely the Mitsubishi version of the very popular 78xx and 79xx voltage regulators sold by a lot of different places. They appear to be dated [old, obsolete, well maybe not dead yet - what a surprise...], and there are better alternatives out there now.
What I did not realize, various manufacturers use different internal IC circuits to implement the voltage regulation. Here is a really interesting web page:
https://www.righto.com/2014/09/reverse-engineering-counterfeit-7805.html
Here’s a good voltage regulator design article:
https://www.electronics-notes.com/a...y-electronics/7805-7812-voltage-regulator.php
And another one, on an audio page.
https://sound-au.com/articles/vi-regulators.html
Apparently, the 7805 has no provision for handling a low voltage:
https://electronics.stackexchange.c...output-if-input-is-lower-than-5-volts-lets-sa
So again, here’s the actual data on start-up (power-up) on the turntable:
The big question still, is it the main power supply or other electrolytic caps that are bad or is this the normal start-up for this chip? Because it's burning out the tantalum caps...
Well, still looking on-line, let me know if any of you all have any thoughts...I'm not replacing anything till I am sure it's going to last another 40 years...
