I’m using a Saga S also … I also like it … I use passive half the time View attachment 2908469
I have run seprates since 1983, my Saga + has impressed me, SQ per $, from the get go!!picked up a schiit saga s to use with an optoma nuforce sta-200 and it’s magical. the schiit saga s absolutely stomped the preamp of my c326bee into oblivion it wasn’t even comparable
My amp is LINN LK 140… 95 WPC @ 8 ohms…140 WPC @ 4 ohms…what amplifier?
I could see passive working well for some stuff or maybe some amps. I was told this sta-200 with its high gain may require the passive stage but I’ve found the active jfet buffer to be more enjoyable on the music I listen to which is a lot of metal
I just picked up another piece of Schiit: I’d been biamping my speakers, using my AVR as a pre, driving an emotiva mini-X 100 for the woofers and a P-P EL84 driven tube amp for the tweeters and mids. It unfortunately died last weekend, so I ordered a Schiit Sys, so I could switch between sources and control the volume with a single knob. It did’nt hurt that it’s made in the and it performs beyond expectations. It’s remarkably simple, with 2 inputs, a switch between two sources and a solitary volume knob. It adds zero color to the sources and adds no noise. While the price point was higher than its Chinese made equivalents, the build quality is quite high and the components seem well sourced. While I’m old enough to have misgivings about the clutter of multiple small devices cluttering my hi-fi stack, Schiit gear performs exceptionally well.
That Nuforce amp is well known for not mating well with passives. the input impedance is a bit low for that.what amplifier?
Yes that's it, I made it up entirely.honestly, where did you get that information? did you just make it up entirely? are you thinking of a different amp?
I must be remembering a different amp, but hopefully it was a Nuforce at least. It had an input imp. in the twenties when I checked it.Spec is 51k, has it been measured and found to be much lower?
was gonna say this sta200 seems to match about as well as ive heard anything match with the schiit saga s (especially imo) considering the power hungry br-1 daytons its driving. the saga s destroyed the preamp of my nad c326bee and its far from a passive buffer. i read a lot of people actually recommended a passive pre for the sta200 prior to purchasing it, with the saga s being speculated as a likely well matchI must be remembering a different amp, but hopefully it was a Nuforce at least. It had an input imp. in the twenties when I checked it.
With an input imp, of 51k, you would expect it to match well. that's my experience.was gonna say this sta200 seems to match about as well as ive heard anything match with the schiit saga s (especially imo) considering the power hungry br-1 daytons its driving. the saga s destroyed the preamp of my nad c326bee and its far from a passive buffer. i read a lot of people actually recommended a passive pre for the sta200 prior to purchasing it, with the saga s being speculated as a likely well match
one thing I do like about vintage gear is the wood cases and cladding. To that end, I've tarted up my AVR and disc transport; black goes well with mahogany:Best part of all, no silver faced BS, black is beautiful![]()
And still no silverone thing I do like about vintage gear is the wood cases and cladding. To that end, I've tarted up my AVR and disc transport; black goes well with mahogany:
perhaps I'll see how it works with the Schiit stack, once I've caught up on my other projects.
Here's what blows me away: Schiit charges extra for silver cases and presumably, people are eager to pay the premium.And still no silver![]()
I "painted" my old SMSL M8a black.Unfortunately both of my SYSs are silver because I purchased used ones.
Good news is I just got a used black Zamp V3 revision 2 with only a power button on the front.![]()
