SE 45 tube amp and tubes available
I'm working on a 45 amp that uses a filament supply that is simply derived from a resistor dropping the Voltage from a 6.3V filament supply. The amp uses a converted Wurlitzer organ amp chassis.
DHTs being what they are, seems to me the filament Voltage is critical; something a simple resistor won't do. I've found that various 45s express a different amount of filament current, thus causing the Voltage to change too.
I found a DC to DC converter on Mouser that makes 2Amps at 2.5V. It can take roughly 5-25VDC as an input. So I'm using some rectifiers from that 6.3V supply to make a DC supply that should do the job. The converter is tiny! It regulates so hopefully the 45s will behave better with that as a supply and it might hum less too (or not at all)- always helpful when the amp is such low power...
DC heat on a DHT just seems not quite right to me. Maybe its not as big a problem in reality as it seems in my head but with one end of the cathode effectively being more negative than the other by 2.5 volts, it just seems like it wouldn't emit equally and that has to do something to how it performs.
and yes I know early DHT were frequently used on batteries, so DC supply.
Push-Pull 45s and 2A3s can easily use AC filaments, with very low or no hum heard.
DC filaments do change their sound character, imho...
Are 50 tubes being made now? Those were pretty short lived back in the 30s and when you find one they are either big money or used up.
I like the woodwork
I like the woodwork
Apparently they are but I have not tried one so don't know how good they are.
EDIT:: Also not entirely sure they are easily avaliable
Frannie
Hiya,
IMHO the best DHT is the 2A3 (Higher wattage , easier availability and more reliable)
Reasonable old stock and a wide range of new production tubes to choose from.
As far as sonic comparison to the Type 45/46 I don't know to be honest.
Frannie
I was referring specifically to the 50 tube, not the amp.
I've never heard of this person before, but that doesn't really mean much. If its not decades old, the chances of me having ever heard of a thing diminish greatly
I dont know, but just looking at what he builds, those are no joke works of art and will cost you $8500 and a long wait
That's the kind of money you pour into a ride, not an amp...unless you want that bling factor.
Have you ever thought about building a tube amplifier?
Dennis Had's builds are excellent. I own one of his parallel 45's and it is a glorious sounding amp paired with the right speakers.
As to whether globes sound better than ST, I have used both with different speaker pairings and tend to prefer the ST RCA's.
I have not tried the EML 45's, but will likely spring for a quad down the line. They come with a 5 year warranty for everything except wear and reports are that they last a very long time.
I do know someone with a great deal of experience building and designing, and the 50 triode is their favorite tube for sonics, though they use 2A3s themselves for the aforementioned reasons of cost and availability. They have built dozens of 50-based amps for customers though.
