SE 811 amp schematic...
which schematic are you looking at ? there are a couple linked here.
A 6J5 is half of a 6SN7. I'd be fine running a single 6SN7 for both channels, using one triode for each vs a pair of 6J5 tubes. That wouldn't even require any change, other than remembering to use the proper set of pins for each channel.
I know you are exactly right, but for some reason I always worry about cross talk, even though I've proven to myself it's not an issue. Maybe because they have that shield between the sections on a lot of 6CG7s, but that is probably for some other reason. One of my very favorite amps uses a single 12AX7 for the first VA, one section for each channel, and the soundstage, and imaging are fantastic. I just need to get over it I guess.:D
well, back to my parts bucket selection methods again. I've got lots of 6SN7 tubes, so I'd use one for no better reason than I have a couple dozen.
The schematic is on post #14, I deleted the other one... 6SN7 will work with only one section connected, right? I have some 6J5s but most are metal...
I'll see if I can get it to work with the positive grid problem I read about, as its not mentioned in teh design,,,
The OP sent me a schematic that he used the 5651A voltage reference tube in, but I don't understand how to use it here...
Another guy said this amp design won't have enough gain with a 6SN7... I don't know all the theory, so I'll build it and find out!!! May need an old welder transformer for the heater supplies, tho!!
Regards,
John
it would work using only half the tube, but since you'd end up using two halfs, you could just cheat and use a single 6SN7 and have it run both channels.
Metal 6J5's are fine too. The metal acts as a built in shield if you ground pin 1. They don't look cool, but they work fine.
if it needs more gain, a 6sn7 per channel with one half feeding the other would add plenty of gain.
Thanks, that was the question,,, I just need half 6SN7 to mock up one channel,,, or I could use a 6J5.... Would a front end section similar to teh 6L6 amp (6SL7s sections in series) work here, if it needs more gain? needs resistor changes tho, right...
Regards,
John
6AS6 is common and cheap, many other tubes with same basing. cathode follower stage could be 6BK7 (closest sub for 6P1P) or 6SN7.
Thanks,,,
The more I look at the one with foreign tubes, the more I want to stick to the 6SN7, 6V6, 811 design,,, Don't quite understand some of teh symbles,,, Is that angled line going thru the resistors indicating a pot? the line, perpendicular to teh angled line isn't indicating ground, is it?
Regards,
John
Thanks,,,
Regards,
John
Got rained out of a Hamfest today, so I got some shop time...whacked this one together with parts on hand,,, Ugly ain't it!! Now to modify a PS, and steal a OPT off something to try it out,,,
And the learning continues...
Regards,
John
Got it!
Had a bad cap in one of the DIY cap "bundles", but sorted it out quickly,,, fired up on the next try...
Using all AC for filament and heaters for now, so it has a little hum, but that shouldn't be hard to get straightened out... That 811 is just in time for the Fall, couple of those guys can heat the room!!!
The big Maggy PS has no problem powering this guy, but, I used two separate FTs so I could use the variac to dial in the B+ without affecting the heater V, it worked out very well...
An old 2.5K OPT ,is biggest one I have, but I think this amp wants a 3.5K primary...
This is the first build I didn't break in on Pink Floyd, and it still worked!!!
I used the schematic as posted, with the caps/resistors on hand, and voltages are pretty close... I'm open to any suggestions or improvement anyone has to offer...
This just too much fun, and not as greasy as building engines!!
Regards,
John
If you're using this schematic:
http://www.audiokarma.org/forums/attachment.php?attachmentid=543772&d=1412193976
I notice there is no heater circuit balance. Directly heated tubes can work OK on AC heaters but sometimes you have to use a hum balance pot to make it go. here's one way to do it, and it will give you your cathode resistor too.
basically its a 100 ohm pot between the heater legs, and the cathode resistor ties to the center wiper. Tweak the pot for least hum. you may have to play with the value of the cathode resistor though since the pot itself adds about 50 ohms per leg to the total resistance. it may actually work out that you will just ground the center wiper of the pot and let the ~50 ohms on each side work as your resistor.
Trying to follow your thoughts here,,, are you saying to replace the two 51ohm resistors with a 100ohm pot, take it to ground, and use it as a hum pot? Looks like your circuit has a Kr (820ohm) mine doesn't?
I can try the hum pot, was thinking of DC heaters, tho...
Regards,
John
Thats whatever a 2A3 happens to need. The values for that are not likely to be correct for an 811. The pot wiring is what I was trying to find an example of. You may or may not need a resistor between the center wiper of the pot and ground. I don;t know the particulars of biasing an 811, but I'm thinking that if you are currently using 51 ohms to ground on each side of the heater, a 100 ohm pot with the wiper in the middle is real close to that.
If that doesn't get it done, DC heaters should but the pot may be worth a try. Just keep in mind it would need to be rated for whatever wattage those cathode resistors are dissipating, else the smoke will come out.
He cannot use auto bias with tubes like 811. So resistor's values should be lower.
I'm using 50ohm 5W, all I had on hand... the heater draws 4A... Don't think a regular 1/2W pot will cut it! Also, looking at teh schematic, and not up on Chinese, it looks like they used some kind of regulator, that is set to 6.2V4A...
I'd like to try a pot, just to see if it works, not sure I have one big enough, tho...
Regards,
John
Those 50ohm resistors are biasing the tube at 22V, schem calls for 20V, with 51 ohm,,, these were close as I had...
Regards,
John
Little update...
Working on it some more,,, Built DC power supply for teh 811 filament, to get rid of some hum,,, worked out pretty good, just a little left, so I'll put teh other tubes on a DC PS as well... Also, added a 1.0 input cap to protect the CDP...
Got a few readings...
At 355DCV B+, 811 plate 340DCV,,, Grid 23.7DCV, ( up from 22VAC, with the addition of DC heater supply )...Pin 1, across 50ohm resistor is 4.46VDC, pin 4 -1.58...
Seems like its getting there, sounds pretty good, anyways,,, but always interested in what teh experts have to add!!
Regards,
John
Here's some readings teh 811, Is themath correct, does it sound reasonable,,,
Thanks...
Grid,... 8.2K reads 8.2K( 8200) V across, & 79.2V...
So, 79.2 /8200=.0097
Plate resistors read 4.53 and -1.47= 6V and 50.4 + 50.4 ohms= 100.8,
6/100.8=.0595,,,,,, .0595-.0097=.0499
Regards,
John
Built a DC filament supply for the 811 with a variable transformer, still using the 50ohm resistors,,, Got the V back up to 6.3vdc, moved the other DC heater supply to the other tubes, and get no hum at all...
Experimenting with feed back, and it seems the amp would need more gain to use it... Is there an easy way to put the unused section of the 6SN7 in series with the 1st section, to boost gain some? I see the 6SL7 used that way on a 6BG6 SE amp I've been working on, but not sure how to size resistors/caps properly...
Thanks ..
Regards,
John
Thanks ..
Regards,
John
Easiest way to get more gain without really changing circuit - use CCS instead of plate resistor of first tube. Look at IXYS devices. You only need two resistors with them to add CCS to your circuit.
