SE 811 amp schematic...
We were typing at teh same time,, I'll wait on any more mods til you can catch up...FWIW, I don't mind messing with the bias at all, this is a learning exercise for me!! This thing is really starting to sound very good,,, lots of Bass, good highs, and on a marginal OPT and speakers...
PS: I got rid of FB,,, pretty sure it won't be needed....
Regards,
John
That all looks pretty good but it is hard to get the full picture without knowing the operating conditions of the 6L6 and 811. The next thing I would suggest is to install a 10 ohm resistor in the cathodes of the 6L6 and 811 so you can measure the currents through the two tubes. That way you would know the complete operating conditions of the two tubes; both plate current and voltages. Then you can compare the operating conditions you have with what you expect. Draw up a schematic with voltages and currents and the amp can be fine tuned from there. This is a very cool project; I may have to try this myself. Have you got a 'scope and signal generator?
I have scopes,,, no signal generator, tho...
I can never leave well enough alone, so I went back in, and changed it closer to schem figures for the Vp on all teh tubes... Heres where it is now,,, Vp 811=378V,,6L6=256V,,6SN7=68k 92V...
811 Grid= 27V ( schem says 24v),,, 6SN7 K=3.23V.... This is with 8.4K B+ resistor, 1K replacing 8.2k, and 68k replacing 82k... it does sound very good, clean waves w/scope connected to speaker terminals at all volume levels...
I can't find much data using 811 as SE audio amp, other than info from some schems I gathered,,, so. I'm trying to keep teh 811 Grid as close to the the design specs(24V) I have as possible, but raising B+, to use as much of its potential as I can...
I will install 10ohm resistors in teh K circuits, and take readings...
It doesn't really have the gain I expected with 6SN7, and didn't sound as good with 6SL7,,, so, how hard would it be to use both sections of 6SN7 to drive it? I think this was mentioned earlier in the thread... Just another thought,,,, these 811s are way to cool looking to stay in boxes!!!! and using a 6BG6G also adds to the cool factor!!
I will draw a schem of how its configured now...
Thanks,
Regards,
John
Glad you like the build!! Its good to have collaboration...
Here's the present schematic......811 grid=26.8V,,, 6SN7 K=3.1V...
Hope this is readable, got one pic and battery needs recharge...
Regards,
John
I added a second stage to the 6SN7, its from a 6L6 amp I built, and used the same R values from teh other amp...
It increased the gain a little, but maybe not enough to continue using 6SN7...
Regards,
John
Revisiting the 6SL7,,, I have it running both sections now, but it pushes it to distortion at max volume,,, I think one section, set up properly may be the answer... Too bad, as I would rather use 6SN7...
Any other octal drivers I should try while I'm at it?
Regards,
John
A 6J5 is half a 6SN7. A 6sq7 is close to half a 6SN7, with 2 diodes that would need to be tied to cathode.
Yep,, I know about them,,,I'm running a 6SN7 now, with 1st stage driving the second.I assume its wired right? This sounds really good, I just thought something with an AF between 20 and 70, may work also...Like say an octal version of 12AY7, or 12AT7...
Just not getting the volume I expected,,, maybe I'm just not used to triodes...
Its a fun project, tho...
Let me know when you're up this way,,, I'm sure we could figure something out!!
Regards.
John
Regards,
John
Change plate resistor to lower value until you get about 130 volts at plate of first tube.
John,
That's why I asked you if you had a signal generator: you need to determine the gain structure of your amp. In other words to fine tune the amp you need to inject a signal, say .5 VAC sine wave into the amp and look at the signal at each stage (for distortion) and measure the AC voltage. That way you can make sure that the last stage clips first. You don't want the input stage to inhibit the amp from reaching full output, for instance.
I use a cheapo ($57) Tenma 72-490 from MCM electronics but I am sure there are others that would work as well. You can also use a CD player with a test CD that puts out a 1k hz sine wave; you would adjust the input signal with a 100k pot at the grid of the 6SN7.
Looking at the schematic on post #64 we can see that with the bias of the 6L6 is at -27 V; that stage should clip with a 27V input. So if you assume the gain of the first stage is about 18 (that's where the sig gem comes in handy) then we can see that we need about 1.5V P to drive the first two stages to clipping. But we still don't know about the output stage clipping. Does it clip with less than 27V input to the 6L6? A sig gen and o'scope will tell the tale....
Ended up with 30k resistor,,, Last readings are in the 30k column... Overall, the amp sounds very good...
Regards,
John
John,
If by clipping you mean audible distortion at a certain volume, it doesn't distort at all at any volume, at least I can't hear any change, nor see a difference in the waveform on the scope connected to the speaker terminals...
I don't have a signal generator, but may be able to borrow one,,, however, the great task will be learning to use it!
Also, I'm confused at the "-27V bias of the 6L6"... that stage provides a +VDC supply to the 811 grid...With the latest Plate resistor change to get the 6SN7 stages to 130V, the 811 grid is now +25.5VDC... The amp has a lot of bass, and the highs are very clear, with a little more volume then when it was running 90V Rp...
I'm basically a novice at this, and am bulling my way thru with the help of guys here,,, and trial and error... I will try to get a signal generator, and with practice, may be able to sort out a little more theory on my own...
Thanks for the continued support...
Regards,
John
Here's a couple pics of it running... decided to used both sections of 6SN7 1st stage, 6BG6 2nd and 811... Sound good,, and looks pretty cool in the dark... Pair of 811s should light a room, probably heat it too!!!
Regards,
John
Re thinking the first stage and decided to try 6SL7 again, with the raised plate V,,, Here are readings with 6SN7 and 6SL7, and no resistor changes...
The amp has a little more gain, measured with a sound level meter,, and no apparent distortion on the scope...
Is it OK to run 6SL7 with these V readings, or can it be set up for even more gain?
This amp sounds very good, but doesn't have the ear bleeding volume I thought it would, however, it is my 1st triode...
Regards,
John
30K ohms is not a sufficient load for the 6SL7 and that is restricting your input voltage which is restricting your output voltage, limiting your overall "volume." Change the 6SL7 plate resistor to 100k with a cathode resistor of 1.5k; that should give you Ep = 150V, Ip = 1mA with Eg = -1.5V.
Get a cheap signal generator. Inject 1VAC into the first tubes grid and check the output on the 'scope to look for distortion; measure the AC voltage on the plate. do the same for each stage. The last 811 stage should distort first or you need to re-engineer the previous stages.
Thanks for the input...
Here's the results of the resistor changes,,, .86 mA on pin 5 Plate 2... G1 (pin4) is .6V positive,
Regards,
John
Update...
I changed the 100K plate resistor to 82k, and got Ep right on 150V...
Still working on signal generator... May be able to borrow one,,,,
Regards,
John
I don't think that the 6SL7 will make a very good cathode follower. I thought you were using the 6BG6 for the CF. The grid of the 6SL7 should be at ground level; the .6V on the grid is messing up your bias. Have you got a grid resistor on the grid?
No, there is no resistor on G2 (pin1 6SL7),, schematic is on post 75,,,
I'll draw a new one, the way the amp is modified now,,,
Regards,
John
