John,
Don't sweat the signal generator. All you need is a 1 VAC, 500 Hz sine wave; nothing more exotic. You simply need to be able to measure the AC voltages through the amp to ensure that each stage contributes its be share of the gain without distortion. A sine wave is easily "read" by your DVM, and 500HZ or 1kHz should be within the range of the meter. Reading AC voltages over 1kHz can be a problem for cheap meters. Sine waves make it easy for you to visiually see distortion.
The first stage should make an easy gain of 70 using the operating points we discussed. The second stage has no gain but appears to be operating correctly, so the question is: with 1 VAC input to the 6SL7, can the 811 be driven to clipping? I think that the answer is: no problem. So I think that what you are really observing is that you need way more voltage on the plate of the 811 for more meaningful output.
