I have a whole file/cd of various tones and test signals. If we can find a way to transfer it, big file, and you want, I'd sure send it. Maybe on Sendspace et al.
It's the Bink audio test CD. Sorry for long post
Tracks 1-2: Track Identification. These tracks will help you confirm the correct Left and Right patching and routing through your system. Track 2 has (in order) Left only, then Right only, then both Left and Right together (Center), then Left and Right with inverted polarity (Surround.) If your system has a polarity problem somewhere between Left and Right then the "Center" sample will sound unlocalized or absent and the "Surround" sample will seem punchy and centered. In a mono PA "Surround" should disappear completely.
Track 3: Dual Tone 700/1000. You can send these tones panned to extreme Left and Right to a broadcast or recording feed to set levels and to verify Left and Right channels. Left = Lower frequency = 700 Hz.
Tracks 4-5: 700 & 1000. These are level-setting tones useful for channel gain pots, compressor and limiter levels, feeds to external mixers, etc. 1kHz is the de facto standard of broadcast audio level setting -- your satellite and mobile recording techs will expect to see 1kHz coming from your mixer. You still need to chat with them to define whether you are sending them A) the absolute ceiling level beyond which you'll never go or B) some idea of unity level or 0dB which includes a certain amount of headroom for peaks in the program. You should loop or repeat Track 5 if you need to send 1k tone for longer than one minute. You can also listen for crosstalk in your gear using these tones. For instance, check to see if your Aux sends leak some of this tone through when you assign the CD player to the main bus or the PFL bus.
Track 6: Log Tone Sweep. This track is very useful for listening to your speaker systems in order to catch any peaks or valleys in the response. You will hear a brief dip or jump in SPL where the response isn’t ideal. Outdoors the response curve you hear will be mostly speaker- and array-related. Indoors you will also get a lot of room response characteristics coloring the pure sound of the sweep. Knowing your own personal hearing curve will help you translate the sound of this track into beneficial system adjustments. A note: Listen for swishing and swirling sounds mixed in with the pure tone sweep to see if your CD player is poorly made or if something in your sound system generates harmonic distortion. Before critical listening please ask others in the venue to be quiet as this track more than any other makes people want to joke around by whistling or singing along -- it reminds many people of a cartoon where something is going to blow up..! But the high frequencies are rolled off at a gentle and constant rate to keep them from taking anyone's head off. This track is meant to be played at a constant fader level from start to finish.
Track 7: Linear Tone Sweep. This track is like Track 6 but is for fine-tuning the HF response of your sound system. You can hear more clearly how your various higher bandpasses work individually and how they blend together. Due to its linear contour, this sweep goes quickly from 20 Hz to 2k and moves much more slowly from 2k to 20k. Using this track with people around will not make you any new friends…
Tracks 8-10: LF Warbles. These up-and-down sweeps are for confirming your subwoofers’ smooth transition to your LF drivers. Pick the warble which is centered closest to your subwoofer crossover point. Playing this track will help you hear things like bandpasses out-of-polarity, SPL gaps between bandpasses, SPL peaks from overlapping bandpasses (very common) and room response quirks. Check to see if there is a sense of motion (a seeming change in location) from low to high and back as the sound shifts from sub to LF. You are looking for a solid wall of warble, not shifting localization.
Tracks 11-44: Pure sine wave tones. These tracks include those centered on the ISO frequencies found on 1/3-octave graphic EQs. (1kHz is missing in this sequence since it is available at Track 5.) You might find these tones useful for ear training so that you can spot feedback frequencies more quickly during gigs. Have your tech friends quiz you as they play a track back. You can also use these tones to check driver polarity within a bandpass. Pick a frequency close to the middle of a bandpass (far from crossover points) and move your ear from a line through the center of one driver to the center of another driver in the same bandpass. If there is a level dip between them then you have a polarity problem. Several extra non-ISO frequencies are added in the lower ranges to help you understand the performance limits of your LF drivers and your subwoofers. The lowest few tones can help you determine the proper level of subwoofer HPF -- that is, whether you have enough 'low-cut' to keep your amps from overheating and to save your sub drivers from overexcursion. Very few live sound systems will yield any measurable SPL from the highest tone, 20kHz.*
Tracks 45-47: Piano, Drums. These soulless instrumental tracks (no Grammy in sight) are presented dry (no effects) and can serve as a reality check for system confirmation.
Track 48: Metronome 120bpm. You can use this track after setting delay times to confirm that the main system meshes neatly with the delay system(s). Of course, if your delay is off by exactly 1/2 second, this track won't help you at all...
Track 49: Crest Wave. This sound is a jarring mix of 100 Hz, 200, 300, 400 etc. tones continuing up the scale in 100 Hz steps to 1k, then in 500 Hz steps to 10k, then in 1kHz steps to 20k. Like white noise it can be used to set levels on gear not including speakers. Even though there is no DC offset, the energy of this complex wave touches the positive digital ceiling but only gets ~ 1/3rd of way down to the digital negative limit. Peak amplitude is 0dB. Average RMS power is -16.13 dB. This track can damage speakers if played too loudly.
Tracks 50-51: DC Offset. These tracks look like flat lines on a graph; they are not sound*(requires login)
