SE 811 amp schematic...
Don't have a set of probes with the scope,,, I just have a set of shielded leads with clips that I used across teh speaker leads... Guess I'll need to make a set,,, will 10M work on any scope? There isn't an AC-DC switch on this old scope,,, maybe it isn't up for teh task?
Regards,
John
Regards,
John
You really need a working scope if you want to make something useful in audio. Even $100 worth 20MHz one will do the job in this case. Search local Craigslist for 20-50 MHz analog scope in $150-200 range and then talk it down to $100-150. Make sure that it comes with probes, otherwise you will have to spend another $20-30 for them from e-bay. And please get software signal generator for your computer - it is FREE.
Made a 10M probe, connected to 6SL7 plate... here's the wave on teh scope at full volume, 5.3VAC across speaker terminals...
Regards,
John
I simulated input stage in MicroCAP. At 1V at input it produces more than 1% of harmonics, mostly 2nd. I used 12AX7 tube model, which is very close to 6SL7.
  • Screenshot from 2014-12-12 14:33:43.png
I appreciate your help,,, I've been trying yours and Palustris input,,, and I'm a little lost! Your simulation has the 2 triodes in series, from an older schematic,,, the 6SL7 now has both triodes in parallel,(see post 87)... The waveforms I posted are from this design...
Regards,
John
Huh? Why not just use a 6SL7 model? Their transfer characteristics are shown below for comparison (6SL7 in black and 12AX7 in brown) - they do not appear to be that close...
Cool graph!! I don't understand it, but I'm still learning!!
Well. 12AX7 has an AF of 100,,, 6SL7 = 70,, I guess that makes the difference in the graph? Remember, the original schematic used one triode of 6SN7(AF20), actually it used 5693/6SJ7(AF19) as teh 1st tube, so its possible I'm overdriving the 1st stage? but it sounds good, and has much better gain so far...
12ax7 is in Mc library and 6sl7 is not. I would need to make an additional effort to import it.
I do jot say that I get to exact match, but at least it allowed me to check if circuit is viable.
for_p1 - No worries, just pointing out the distortion figure from the sim may not correspond to the actual circuit, since the transfer characteristics of the two tube types are quite different.
knockbill - The AF only tells a part of the story, by itself, it's not useful for estimating the distortion level. Also just to confirm the latest circuit configuration: 2x6SL7 -> 6BG6 -> 811, is this correct?
OK,,,Yes, that is teh correct tube line up... Post 87 has the input as it is now configured... I was going to lower the value of the Rp as suggested by for P1 until I realized he was looking at an older schematic...
The rest of the amp hasn't been changed other than raising the voltage of some caps...
Quick design tip - take a look at the RC coupling table in the datasheet for some typical values, e.g., for Ebb of 180V, Rp = 50k, Rk = 700, Rs = 240k. The values for Rp & Rk are halved to account for using both halves in parallel.
I have, Just don't get the relationship, tho,,,,from 6SL7 Ebb =180V, Rp range from .1, .22, .47, numbers look like cap values rather than Resistor...Rk ranges from1900-9100, not 850,,, I'm not saying your figures are wrong, I don't understand how they correlate to teh RCA manual.... I looked up teh values of most schematics I used in teh coupling tables, and never saw the connection...
Rp is expressed in MOhms, Rk is expressed in Ohms. So Rp= 0.1M =100k for one tube, or 50k for two tubes, Rk=1400 for one tube and 700 for two tubes (typo in my previous post is corrected - I really need better glasses...), on so on.
Ok,,, thanks,, I'll look at it again,,, I thought the schem would work as originally drawn, didn't count on needing more gain,,, this is how you (I) learn!
The schematic as drawn does work, I was just showing you how you can use the table from the datasheets to alter the values if you don't know how to design the stage yourself, since those values have already been worked out by the factory engineers.
Thanks, I appreciate the info,,, I missed the Mohm notation in the manual... I'll try to modify the 6SL7 with the specs and see if the wave looks better...
Using specs from the manual I replaced the 2.2k Rk with 1k,,, and 200k Rp with 47k,,, Plate voltage is 168VDC, grid is 1.54V.... This amp sounds too good to be very far off... lots of bass, brilliant highs,,, more than the test speakers can handle at higher volumes... I'm going to have to send a good clean signal thru teh amp to get accurate readings, but until then, its sure worth listening to!!
Thanks again for the additional info, I'll get it yet!!
Great, it seems like you are on the right track. Love to see some pictures of the build once you wrap things up.
