SE 811 amp schematic...
If you don't need the extra power, then you can leave the B+ as is, especially since you really like the way it sounds now.
I put a couple big computer caps in series, but could only get 400uF/500V out of them, Took the 811 off the 1st stage, at about 465-470V, and used dropping resistors for the other sections so they wouldn't change... I couldn't really hear a difference, so I guess this is where the clean input signal and good scope come in to play!!!
I think it would be fun to see how they sound with the 811 pushed, tho... may have to spring for some HV caps...
I found a pair of 330VAC caps, could get 660V using them, if this PT co-operates, if not, I have an 800+ V one I could try, and maybe the one Gadget offered... Can AC caps be used in DC circuits? do they need to be de-rated?
Thanks...
Valve's World has quite a few 811 amplifiers that all ran around the same low B+, so perhaps they figure that it was the sweet spot for the tube. Also just to verify the operating conditions, I think you said the OPT was 2.5k and the grid was bised at ~-25V, are those figures still about right?
I'm using a 2.5K/8ohm OPT, because that's what I have,,, it isn't on the original schem...
Vg went up some, its about 26-27, before I raised teh B+... Think I'll go back to the"sweet spot", before today's efforts,,,,, I still need a good set of output transformers, so, bigger caps/ higher Vp sounds like a gamble, that probably won't pay out....
I'll have to look up Valve World...
I think you can stay with the 2.5k OPT that you already have, in fact, you get a bit higher output power. The original 811 schematic that you posted was from Valve's World...
OK,,, Its an antique radio/console OPT i found at a meet,,, problem is, I only have one! But its pretty big, and works good for testing... Thought I heard of Valves world! Getting old, memory isn't my long suit....
Here's a pic of the modified PS,,, think I'll dial it back where it was and work from there...
Any thoughts on using AC rated caps in DC circuits?
Thanks again for the input...
Thanks...
You could experiment with a voltage doubler circuit...
I see, then I guess you would need to order 2 new 3.5k OPTs, are they going to all fit on the chassis? I thought there were only 3 irons on the mock-up layout, if so, where are the choke and the FT for the 811 going to be located?
I can easily get teh voltage,,, its limited by the caps I have...
Yeah, I was looking at trying to push some tubes with HV at one time. Figured by using two caps in series I could get 50uf @ 1,000V for about $8.50. That was using name-brand caps like Panasonic purchased through DigiKey. Cost goes down fair bit, nearly by half, even if you could drop back to 900V by using two 450V caps.
In the voltage doubler though, I think in the primary/doubling stage the caps only see half the voltage.
Caps see half voltage in a doubler rig, and so do the diodes. That was a large part of why they used it. Early diodes couldn't deal with the PIV that a conventional full wave could. If you look at the voltage ratings on caps in a typical doubler circuit, they're usually only about 250v for an amp with 400vdc B+. Any caps after the doubler have to be able to deal with the full voltage of course, so with 900vdc you're likely still dealing with caps in series to handle it.
No, there are four Tx on top,,, PT and FT are in the middle, (see pic post 142).. The two Tx on each end are just matching PTs I used to mock it up,,, Usually put chokes under the chassis, near the PT...
I'm always looking for Transformers,,, chokes, FTs, and PTs are much easier to come by than OPTs, tho...
If I'm not mistaken, if you double the voltage, you only get half the power (amperage) tho... Need amperage to prevent sag/voltage drop...
But, the higher V was suggested, so,, I had to at least try it!!!
Yep, misspoke about power, as that = Watts....
Got about 400VDC on the 811 plate right now, sounds just fine,,, I'll spend the day monitoring, and listening to it,,,, Got about 14 Pink Floyd CDs, so it will be time well spent!!!
I think this PT I have will work fine, at this voltage, and there's still room to remove some resistance and/or crank up the variac for the other channel... Just have to make sure the 6.3V winding is up for the 4 small tubes, I need about 3A... Unless I build a doubler out of the 5V winding, and use it for the 6SL7s ???? Hmm,,,seems it's always something!!!!!
Thanks for the input,,,
I was going to try higher V, but didn't have caps to go higher than 500V and that seemed to be going the wrong direction,, figured someone smarter than me figured these voltages, and it sounds pretty good here, so...
I need to connect it to better speakers,
Yep, I know what Floyd should sound like, and it seems fine... Not ear bleeding volume, but lots of detail...
Yeah, abstractly that's true.
However, you have to know what you have vs. what you need to understand if the prophecy will be fulfilled or if it's a red herring.
He uses very special circuit, which biases 811 at +25 on grid. It can never leave A2 mode, as grid voltage never gets below zero.
