Working on the PS for the 811 amp... right now its running off a huge Magnavox 2x5U4 parallel PS with a massive PT for B+, and separate FTs, one for the 811 and another for the 6SL7 + 6BG6s... Plan is to try to build this amp on one fair sized chassis, with a PT powering B+, and "small" tube heaters, with a separate 10A FT for the 811s... With the "test" setup, there is no voltage drop, or sag at any volume or bass level at 90+ db, measured on a sound level meter 8' from the speakers... May not be scientific, but its what I came up with!!
Question is, do you think it will work OK on one chassis, or should I just put two FTs on the amp chassis, and use teh Maggy PS for B+? I won't have room on teh amp chassis for three tx besides the OPTs, The Maggy supply is probably overkill for just B+....
Any thoughts or ideas are welcome,
PS: forgot to mention, unless I need a separate chassis B+ supply, the plan is to use SS for heaters and B+...
Thanks...
