So, today I pondered how to accurately test for loss of the RG174 cable. Could not see much loss on the scope at a low signal level. I have a DMM that can do AC volts but can also count frequency up to 4 Mhz. Along with this it can measure AC and display the level in Dbm's.
There is 16 feet of 174 left on the spool that I have so I used this piece for testing. I used a Marantz MA-500 amp as a low impedance source to simulate the output of a pre amp or CD player etc. Put a 48K ohm resistor at the other end of the cable to simulate the load end.
Set my audio generator for 44Khz. most it will do, and set a level at the amp output at +25.0 Dbm's as read on the DMM. Moved the meter leads to the other end of the 174 and measured +25.0 Dbm's. Also tried this test by just using my audio generator which has a higher output impedance and got the same result.
And this tells me that 16 feet of RG174 at 44Khz. has basically no loss. Tested the cable at a few other frequencies in the audio band with the same results. I did not expect this result at all as I theorized that my first test at low levels was flawed and at a higher voltage level and longer length of the cable some loss would be evident. At least a couple of Db's at 44Khz. I thought.
So my conclusion is that the RG174 is not bad as an audio cable and makes a dirt cheap IC for Stereo equipment.
I is good to see AKers doing tests...
My post is a little off topic from the original post...but since the thread has gone to interconnects and types of cable...
But one thing to consider is...It is not only the "Loss" but what effect the complex impedance of the source/cable/end device had on the actual signal.
I would be interested to know what a 44Khz square wave looks like.
When cable is used for phono interconnects it is the inductance (complex impedance) of the phono cartridge along with the complex impedance of the cable that has an effect on the signal.
And this is frequency dependent...So it is not just what happens at one specific frequency...In your case 44Khz...but the relationship of all the frequencies from the lowest to the highest.
That said I do not believe you will see much difference from the low frequencies to the high frequencies with your particular test methodology.
Here is a great link that explains it in depth...
http://www.hagtech.com/loading.html
Scroll down the page a little way an enter the inductance of your phono cartridge and the total capacitance of your interconnects and the input of your phono stage.
For example a Shure V15 has about 500 mH of inductance and 6 ft of your RG 174 would have a total capacitance of about 185 pF. Of course you have to add in the capacitance of the RCA connectors also.
But with these numbers you would have a resonance at about 16Khz.
And of course this is not counting the input capacitance of the phono stage.
A low capacitance audio interconnect might only have about 70 pF total and that would put the resonant frequency out of the audio pass band at somewhere around 26 Khz.
Of course the affect of this is not so great when your are talking about interconnects used at line levels between things like tape deck, tuner and preamp to power amp...
But then again look at all of the differing opinions on the "best sounding" interconnects.
Now back to topic...If RG 174 is used for internal wiring of a tube type amplifier where the cable length is going to be less than 1 ft (Less than 30pF of capacitance) all should be good.
If one is really concerned one could use low capacitance "audiophile" audio cable..at a higher cost of course. As long as the voltage rating is high enough it should work ok also.
