Show Me Your Sansui!
Spring responsibilities have been keeping me occupied and away from my Sansui gear for the last couple of months. A recent surgery has me laid up for a week or so and I know no better rehab or therapy for anything that ails one than Sansui. Also doesn’t hurt that one of my favorite artists just decided to drop an album for the first time in 13 years. Sansui playback delivering every sonic morsel.
Long Live Sansui!
ADS L-1530 speakers. 1980. Everything you see there was made by ADS in the U.S. ADS early on used Braun drivers. If you haven’t heard of ADS speakers look into them. They have gained a lot of popularity in the last few years as more folks have discover them. And also driven their values way up. The L-710 is phenomenal speaker and easier to find right now. My favorite of their smaller speakers.
Thanks. A/D/S is also known in Europe. Not very well, frankly spoken. Now viewing your system on a bigger screen at home I can see that at least tweeter and Midrange look like typical Braun or Canton chassis. It's a nice closed system.:beerchug:
I remember that Braun produced some a/d/s speakers (M10/M12) near Frankfurt for the European market.
I’ve had a 221, 661, and Seven. But a couple months ago I picked up a AU-111 from Facebook Marketplace which needed checking over. It was caked in dust and the guy had no idea when it had even last been turned on. Cost me just under $400 to get it running and it is so so so good. The warmth, deep bass (even with LS3/5A), general musicality, realism of every plucked string etc., everything just feels MORE in a great way. Really excited to get something like Forte or Cornwalls, maybe even Tannoy Kensingtons. I plan on moving somewhere with a much larger room than I have now, so can anyone recommend any speakers to explore pairing with this super special amp. I’d listen all day if I could!
Long Live Sansui!
What is that unit in top right below the turntable and with a blue screen and silver knobs?
No photos yet, sorry, just got a nice au-505 off of Ebay. Used the tuner input from my Marantz-MR-235 also
played vinyl from my dual 1299 -> CJ pv-6 (phono) to tape in on the 505 with AR 4xa speakers. The unit sounds great on the tuner input and tape. Playing around 11. This unit must be more then the supposed 12 Watts. Anyone saying you need effient speakers to play the 505 is missing a real treat using lower effient speakers. Listening to "Let it Bleed". All the seller said was that it sounded good he was using it to drive a sub-woofer. No idea if it was restored, worked on, etc but I don't care as long as it sounds good.
It took me a few weeks to convince the owner to let his AU-517 go. Once I heard it I had to have it. Amazing dynamics and I actually like what the tone controls do for albums that aren't produced as slick as others. The horn shots in Manteca by Arturo Sandoval actually reach out and slap your face.
Then picked up some tired SP-3500s that a lot of people like to crap on. Installed some banana jacks, touched up the solder joints, cleaned the switches, tightened up the 40-some speaker screws, and loosened up the woofer surrounds with some brake fluid. I was hoping a cheap gamble would give me something decent for the upstairs system that looked great, but I'm really kind of floored with how good they sound. I have to tweak on the midrange attenuation values some time, because both the 'natural' and 'clear' settings are too mid heavy, but for now they're perfect. I found an experienced tech who has refoamed these 14" surrounds before, so that's going to get done eventually, and I have to find screws for the grills as well.
It's nice to see someone speaking positively of Sansui speakers for a change. I had a pair of 3500's myself for several years, and enjoyed the way they sounded. The only reason I sold them is that I had a surplus of other speakers that I enjoyed even more.
At any rate, the typical sentiment seen online regarding this line of speakers is not generally favorable. So, it's nice to hear someone compliment their sound. Do you find the low end response adequate, since treating the surrounds on the woofer? The lack of low bass
response seems to be the chief complaint about the sp-3500, and related models
I can see a lot of weird stuff going on with these. There's a fairly large piece of cabinet wood glued inside the rear cover behind the woofer, with factory dampening material stapled over that. Fixing a cabinet volume issue?
There's also a round recess drilled into the inside rear cover to make clearance for the high mid horn. Bit of a whoops but not a big deal.
To top it off though, the labels on the x-over board going to mids and tweets are completely wrong. Maybe that's a case of them using a board design from a previous model and just making the minimum changes for it to work.
There was also factory dampening material glued into those tiny ports in the bottom corners. So to port or not to port dear Hamlet?
Before I did any work to them, I put them on their backs and tap tested the low end. Pretty dismal and very papery sounding almost like a snare drum. After one fairly thick application of brake fluid (let them sit on the backs for a while) and pulling the port plugs, they have a good bass presence. Not so much kick drum bashing your chest, but good extension. Lyle Lovett's Large Band and Joni Mitchell's Travelogue agree.
I have a tech lined up to do the surrounds soon. That will improve response even more.
These 3500s are on my second system, which has a pretty nice Onkyo Integra A8017 and a little digital audio player that has a decent DAC in it. Nothing crazy though. My friend just stopped by to hear them and was shocked. He's got a dual mono Marantz and nice B&Ws as his only system.
After the surrounds are done I'll have a bit over $400 in snow pesos into them, and they look so cool. For more serious stuff it's downstairs to the 517 and Linns, but these are great at what they do. I've read that you shouldn't judge them based on what looks right or wrong sonically, and that's valid. The weird tweeter horns look like they would focus the high end, but the opposite happens and they are prettty even.
I'll concur there are some oddities in the cabinet construction. But the cabinets are actually quite stout and well made, even for their time (before bean counters insisted on cheapening everything up). Even the quality of the individual drivers is good - better than average - for the era. I'd say.
I too have encountered numerous Sansui bass reflex speaker systems with damping stuffed in the port(s), while others were not so treated. It's unclear to me why this was done, as it really makes no sense. On those I've found "stuffed" in such a manner, removing the material and leaving the ports open has always improved the sound, to my ears anyway.
I hope you'll post a thread in these the main Sansui forum once you have all the improvements and updates done to them, and will give your honest assessment of the finished product.
SR 838 - managed to buy it on Marketplace minutes after it was listed for 125 Cdn., plus it came with an Empire 2000T that had its original stylus. I could look at it this way - a nice cartridge with a free turntable.
Using a Shure M 91 ED with HE stylus for now, sounds quite good overall.
There was so much crud built up on the stylus I at first though it was worn but a careful cleaning revealed that the stylus was in very good condition.
Original owner had it stored in a closet for 30 odd years, so far it functions properly except for a frozen pitch control I need to address. Not sure if it is worth cleaning the speed sensor wheel under the platter or opening it up for a check over.
Very clean looking. Well done!
Gorgeous, timeless turntable and a nice cartridge. Headshell isn’t factory. There are quite a few SR-838 restoration and service threads here. Sounds like it’s running fine, as most of these do - they are very reliable. Masterpiece table there. Congrats on the score. Heck of a buy!
Show Us Your Sansui Sticky!
I was kinda lurking around digging for some info when I realized there was no post your stuff sticky in the Sansui Forum. McIntosh, Pioneer and Marantz all have one.
Well it's about time. Show us what you got! :D
AU/TU-555
AU-D11 & TU-S9
SC-3330 and SE-9
9090DB
8080DB
SR-737
SR-838
AU/TU-555
AU-D11 & TU-S9
SC-3330 and SE-9
9090DB
8080DB
SR-737
SR-838
I Just picked this guy up for 80
