isaeagle4031
Member
Those would be the Dayton ND105-4's. The 3" version is very similar to the Auras. These little things have quite a bit of output potential and low bass. Seriously, 40 hz is possible with these little suckers!
This is the current state of my Tuba HT. I still need to caulk a few places and sand a couple of proud edges and then the side can go on. It will be loaded with a Dayton RSS390HF-4 powered by a Oaudio Bash 300W plate amp
GRS 8FR8 from PE. Copy of Pioneer B20.
Cabinet dimensions also from PE.
Just finished them tonight![]()
Nice - did you port the cabinet in the back? what are your cabinet dimensions? I have a pair of the B20's that I was going to put into some Advent 3002 cabinets - but wasn't sure if the size would be right.
Weird, I replaced the Peerless 8"ers in my Optimus LX8's with B20's though mine are not the wizzer. Still, the mid improvement was very noticeable. can't say, yet, there are any other improvements, though I did add more stuffing to help smooth them out some.Nice - did you port the cabinet in the back? what are your cabinet dimensions? I have a pair of the B20's that I was going to put into some Advent 3002 cabinets - but wasn't sure if the size would be right.
Damn old geezer, that's some large enclosures!
I don't know the woofer you use nor its specs, but with that large a box, you might just want to watch for over-excursion not to damage the driver. If it sounds good to you, it's all that matters! :thmbsp:
az
Here are pix of what I did with the Barzilay cabs. They look great from the factory but are really flimsy. 5/8" partical board with 1/8" veneer. As you can see they are really well braced not and solid as a rock....heavy as a rock as well.
That is a JBL E140 woof I will use for the time being until my Lambda TD15H woofers get reconed. WinISD says they will die at 60hz but that is OK as I have 4 subs to pick up the slack.
