Show us your DIY speaker projects!
I recently completed two Altec projects.
One was a recreation of the Model 19's and Z19 crossovers. I built these with a buddy here in the Portland area Brad. We built 2 sets - one for him and one for me. This is a picture of my set
The other was new cabinets for a pair of 604B and some Markwarts crossovers.
Loved the process and I truely enjoying the time listening to both sets of speakers. Tend to listen to the 19's more often.
Cardboard works. A new rage over at DIYaudio is building foam board speakers. I'm itching to build some foam board spiral horns.
My incursion into the Foam Core world...
I recently built a Bill Fitzmaurice T18 horn sub. My diy projects got a lot easier to build with the addition of a bigger table saw equipped with an out feed table, and saw sled that i built.
Cool sub and I'm liking the crosscut sled.:thmbsp:
Very nice work. What type of wood was used for the enclosures? Are the 19's better, sonic- ally than the 604's?
I used 3/4 mdf and then a quarter sawn type of oak veneer . Yes, the 19's sound better. Still got a little more tweaking with the 604's to see if I can get a little more bass out of them.
PR Audio,
WOW! What's your opinion on foam core and where did you buy the boards?
I believe that foam core (FC) in no way is a permanent substitute for wood (ply, mdf, etc). But, if you are not an experienced woodworker, it is a very easy material to work with, it can be cut with a razor, razor knife (X-Acto), or cutting wheel. There is also tools and specialized cutters meant for FC work. Cheap material, so if you over-cut (smaller than correct size), you can throw it away and recut the piece. Easy material to work with, so if you under-cut (larger than needed) just take the piece, mark the new cutting line, and cut with razor. If you get gaps, hairlines, or crooked edges, fill with epoxy or bondo (same as wood). You don't have to sand, like wood. Wood glue on FC only takes 2-3 minutes to hold, and some 10 minutes for a strong bond. You can also use epoxy or hot glue to bond (many prefer hot glue).
Let's take the Planet 10 uFonken design you see (those pics are unpainted enclosures). Though I purchased the 1/2" plywood to build them, I'm not a great woodworker, so being able to make a working mock-up in some 45 minutes from start to finish is great. I was also able to see that I had cut the top and bottom panels too big, so I had to recut with the knife. Now, in my wood panel, I can adjust the measurements of the drawn top/bottom. And, if the FC speakers sound nice, I will keep them (PC nearfield use), and will use the 1/2" baboon plywood for another home or speaker project.
As for the foam core, you can buy local or online from many arts & crafts/engineerig & architecture supply stores. You can probably also find locally at signage supplies stores. Personally, I like www.dickblick.com, though I buy it locally at a school supply store.
I came across a thread in DIY audio talking about the use of FC, people have done amazing speakers with FC. And, I remembered that a couple of years ago, at my son's school they had requested them to bring 6 pieces of flexifoam in different colors. My wife and I didn't know exactly what flexifoam was and purchased 3/16" thk. x 20" w x 30" l colored (one side) foam core boards @ $4.50 each. Well, as it turns out flexifoam is the size of letter paper, about 1/8" thk., solid colors, and a pack of 6 costs like $3.00. So, after two years in my son's bedroom closet, I found a use for those surplus sheets I had. Got plenty for more speaker projects (I see floorstanding 3" to 4" full range horns in my near future).
You can see the finished (painted) Foam Core enclosures here.
I believe I read on one forum that FC boards cost $1 at the Dollar Tree (?)
There are no Dollar Tree stores here, but so I've heard. Though not all Dollar Tree stores carry them, but you can buy online (case qty. only) and they will deliver free to your closest store. I think what people buy from them is what they call Ready-Foam.
Does your time alignment work well? Looks pretty damn nice to me, I bet it is a thunder of great wonder?
I ask too- what is the deal with that amp on the lower left- my God I have seen 55 gallon drums just as small as those to case caps with!!!
DC
Thanks!
it's a mono vv52B (a single-end 25W amp)
This amp can control the crossover speakers very well
Excellent bass on the cheap
I already had the unused amp and the scrap plywood so the driver and passive radiators were my only expense. Around $50 for a nice small sub to augment my H-frames below 40hz ain't bad but I didn't expect it to sound this good.:thmbsp:
picture.php
NICE WOrk! I had/ have that same Dayton amp and it went flaky on me and started dropping a channel grrrrrrrrr! U really like it too! Oh well I guess two years was all I could expect.......
DC
