mesut BALCI
I hope the job in the final will not destroy the manufactured balance on musical parameters. Recapping or changing parts at the first may result optimisation but during listening session, you may not get the joy you previously had. Again fantastic Job. :thmbsp:
One of the most important things on hi-fi that I experienced is balance among parameters which is the thing causing music to be again natural. I never heard a flute or drum or anything played live outside that can be called as very transparent by listeners. Mirko has said that ta-n7 was too transparent!! A destroyed natural balance.
I have been experiencing the tae88. Another device on endless hi-fi path but this is the end, at least one of the ends, and still no miracles I waited for the price. Well it created a room having this time side walls, a complete, closed room. Secondly it has first rate musical pesentation and well defined contours that when combined all together, gives the mood of room.
I also tried my ladder type passive comparing to tae88. I connected passive to the buffered rec-out of tae88. This corrected all lacks of passives and resultng sound still has better purity than tae88 line stage. I found out which cabling is best for passive based sound and for tae88 based sound. At their best results: the music with buffered passive is smoother, more energic, has tiny bit purity obvious, better at trebles, and faster more controlled presentation and even more musical.
music with tae88 is a bit stressed, shows easily 2 times more musical nuances, dangerously dynamic in tiny nuances, mises nothing, pushes what there is on record. You get accustomed tae88 music around 1-2 days. very different presentation, very surprising. The last thing causing real difference between tae88 and buffered passive/5650 pre or all others that I have tried is that, when you are sucesfull tring a bit, you get complete closed room creation and its related mood rather than usual staging. This is the real difference, may be the thing resulting esprit name.
tae88 outputs are one of the worst thing I have ever seen. 2 of my interconnects got defect, there is gravity in practical world. I would prefer tae88 having rca's on the bottom, if this design is really a must. Either way rings must be removed to use cabling into-out of tae88. Very stupid, otherwise an engineering beauty.
I wonder what is the limiting areas of 5650 power amp when tae88 is used as preamp...Is theer really any? I am still seing things tae88 dont have but I get by using other devices. tae88 is not as smooth as buffered passive.
sony units are 5650, tae88, xa7es, sony tv, sony mini recorder, sony headphones walkmans, sony monitor and i have never been a fan of sony.
