restorer-john
Addicted Member
adaptor is merely a processor loop for an eq or dsp or equivalent. I will scan the owners manual if you want it.
john
john
Here is my latest Sony. Is the TC-2850SD dolby cassette player. Wife said she wanted a cassette player to record her students (HS French teacher). So, just viewed this as an opportunity. :yes: Oh, yeah. Was $15.
billbillw,
you should also consider a high frequency oscillation as a source of the buzz noises, which can build up, when local electrolytic bypass capacitors start to age and their ESR increases. High frequency oscillations can be are often noticed as a 100/120Hz buzz noise, sometimes also as a limited soundstage or audible increase of distortion.
Only the bypass capacitors of the supply rails (close to operational amplifiers e.g.) would be questionable.
13-15 years is really no big deal with good capacitors, but it could be that especially these colourful audio caps have a very limited life. Most spec sheets of those capacitors give them a life of 1000...2000h at 85°C.
My TA-E88B preamplifiers have the same Buzz issue. The amp starts to heavily oscillate (with a hum noise present) with volume knob (nearly) all up. More detailed investigation revealed a minute oscillation already present with lower volume settings. After removing that oscillation, by altering the RC-Filters in front of the two flat amplifier differential stages, the problem disappeared and the sound improved a lot.
Btw: This could also be valid for you other TA-E88 owners (!!)
It could be, that your TA-E88 doesn't reach it´s full potential.
The non digital version of the TA-E77ESD is IMO the more serious product.
Glenn, how does it look on the front side, any differences to the ESD ?
Y.E. already told me that he brings his (two) TA-E900's along to Belgium and he noticed that you already made eyes on one of his TA-E900´s ...![]()
no no ... things are getting mixed up :scratch2:
I will only take one with me, but indeed someone local is thinking about offering me enough for the restaured one ... enough so that I can get another backup unit at some time and that I am seriously thinking about doing all the work a second time.
But let's wait and see what happens.
My TA-E901 arrived today.
It looks much better than on any photo I ever saw. It´s really too nice to butch it for parts.
