Does anyone recall where the Shure V15 RS (Radio Shack) cartridge fell in the Shure line? Was it comparable to V15 III, or what? Thanks.
Yes, the stylus was a VN3 variation. But keep in mind that only the original stylus or those specifically designated for the RS, or the VN5XMR will fit. The N97xE will fit, but may not result in a true V15 sound. None of the older V15 (non-x) styli will fit as the metal shaft is too thin.Yamaha B-2 said:Does anyone recall where the Shure V15 RS (Radio Shack) cartridge fell in the Shure line? Was it comparable to V15 III, or what? Thanks.
The N111E is the same as the N97xE, (.2 x .7 mil elliptical) but with a red brush bar instead of a blue one. The M111E/HE and RXT6 were p-mounts.Yamaha B-2 said:Which Shure cartridge was the N111E a stock replacement stylus for?
hakaplan said:The N111E is the same as the N97xE, (.2 x .7 mil elliptical) but with a red brush bar instead of a blue one. The M111E/HE and RXT6 were p-mounts.
Paul C said:The cantilever of the N97xE is aluminum, not beryllium but it sounds the same as the N111E in my RXT6. I have new N111E's and N97xE's here and have done a lot of A/B testing. The N97xE is a perfectly acceptable substitute for the N111E.
The N97xE will replace the N104E, N105E, N111E, N111HE, and will also replace the N92E and N94E stylii. Also NE97HE, VN5HE, VN5MR, and VNSE3HE.
No. They essentially last forever. The stylus is the only part with limited life, either from the elastomer (which holds the cantilever) losing elasticity from age, or a worn diamond. Sounds like someone wants to sell you a new cartridge.jaymanaa said:Not to hijack or derail this thread, but I use V15IIIs, and was recently told that cartridges have a shelf life, due to the magnets wearing out.:scratch2: Is this true:sigh:
NoTransistors said:Sometimes the Type III falls apart, but wear out? None of us have come across that problem.
The sheet of plastic that has the 4 connector pins is known to fall off. The wires shear off with it. I put a spot of crazy glue on its edge to prevent this.
Seth
Forever Analog
hakaplan said:Paul, it will not replace the VN5HE or VN5MR. Those are the styli for the V15 Type V which had the thinner shank. It will fit in the V15VxMR, but the result will not be a true V15 sound.
