Silly overhang question
arcorob
Addicted Member
Does the ATLp120 have the same overhang distance as the Technics SL1200 ? I do the alignment manually but wondering if a Technics overhang gauge would work..one video says it does ? Hmmm...
Measure your manually adjusted setup. If you used the Stevenson nulls then it should measure 52mm if they are the same.
Hi Rob,
I think when I owned my table I sent an email question to Audio Technica about the arm and that is what they told me. In the AT headshell 52mm from stylus to collar....If I am not mistaken, when I measured that it was a 15mm O/H.
This is unscientific...
The Concorde DJ cart (set alignment for 1200) sounds perfect on my PL120
