Simply speakers real AR replacements?
jameswei
I am looking for replacement for AR 9 tweeter and came across SimplySpeakers and they carry Advent and AR replacement. So is it the real thing or something that pretend to be AR?
I went with Vintage-AR on EBay to find two used tweeters for my AR9s. Pricey but they work perfectly.
Yes, vintage-AR have one tweeter listed and its pricy @$129 plus shipping. The Abtech store I can buy two, its $62.50 a piece on Abtech. Is the quality that much different between the two products?
The newer ones may actually be better as they have been improved for better power dissipation. I replaced mine in AR-3A systems about 5 years ago. Rebuilt the crossovers at the same time. The terminals are on the back, so I had to cut a notch in the front panel to get them mounted. Just make sure that the final installation is air tight because the trapped air controls the woofer.
They are different enough to not match the original, so should be used in pairs. The ABT tweeter is much brighter than the original, with more extension into the midrange frequencies. The original tweeter has a smoother response.
AB Tech does not have any in stock, and may no longer stock them. They have been referring people to Vintage AR, who may still have a few. Btw, Simply Speakers is out of stock as well.
Roy
Just check with ABTech and they will have replacements in 90 days.
Yes, the $129 is the OEM tweeter, but I need two so its going to be a waiting game or I can come up with another OEM tweeter.
