SL-1200
Fluffhead932
Does anyone have a counter weight for a SL-1200? Or even an idea of another that will fit on the square end of the tone arm? I picked the table up yesterday and didn’t look at it close enough.
Yep, you didn't look at it very well at all.
This is what you should have had:
At least you have the stub, so I guess the moving mass is not a real issue.
That "counterweight" is an Ortofon accessory designed to go with the ultra light Ortofon cart/headshell combo on the tonearm. With the standard Technics counterweight which is heavier, that cartridge might not even come down out of the sky to be adjusted for VTF.
