One of my local shops wants $65 SF, rep said all the affordable domestic stuff was used up years ago (used to be cheep), and now ships out of Brazil. Some of it had white veins in it, other a green glass like veins. The older stuff I remember was rather boring and monolithic looking, and perhaps more dull and porous (less dense too?).
On the whole plinth verse platter weight debate, I suspect a very heavy platter combined with a light weigh plinth is less desirable than a lighter platter with a heavier plinth.
You don't want the platter throwing the plinth around the room, do you?
There might be a ratio or perfect desirable balance for the two elements. If I said platter/plinth of 33/66 weight distribution how far off would I be?
An important thing to remember is that mass in movement, even a balanced rotational movement will have more potential force than a larger stationary mass. Think of rifling a bullet for instance. More destruction if that bullet mass is spinning, even more so is it's wobbling as it spins like a Sig 40.
